FlyPT 6DOF/Stewart/Hexapod Interface for linear and rotating actuators
Discussion in 'FlyPt Mover' started by pmvcda, Jan 2, 2019.
  1. smitty
    smitty Active Member
    963Coins
    yeah definitely aim for more rotation vs translation. btw i made an edit to the last post, re base size, but it looks like your geometry is OK
  2. smitty
    963Coins
    aim for the smallest L2 and L3 that you can
  3. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,864Coins
    DC motor, 6DOF
    @pmvcda we have hotkeys to map the platform gains in the options (3 buttons). Can I ask to have an axis for it so it’s acts as a rotary pot from 0-100%. For later of course, when you find time for it. Best regards
  4. pmvcda
    15,938Coins
    It's done. Have a small bug there i need to solve.
    For now you can use an axis to increase/decrease depending on axis value being positive or negative, but to feed directly the axis value we have a checkbox and a multiplier that are causing some problems. A new feature in Mover is that you can assign hot controls to any numeric, checkbox or button in the UI. We just need to right click on them to do so.
    Also we can use midi devices to do it also.
    Will try to make a small video showing this.
  5. MartoniczD
    MartoniczD New Member
    22Coins
    Dear Pmvdca,
    Thank you for this amazing software! In my simulator I have to rotate the seat position by 180 degrees. (due to I will place an original dashboard) Is it possible with a pose configuration? I'm having a linear hexapod.
    Thank you,
    Daniel
  6. pmvcda
    15,938Coins
    Linear or rotating hexapod?
    You can just change the L values to make the front equal to current back... Swapp the values
    Maybe I'm not understanding what you mean.
  7. MartoniczD
    22Coins
    Thank you, by changing the L values accordingly saved my problem!
  8. FargusFaustmeister
    FargusFaustmeister Member
    Engineering Technologist
    93Coins
    I apologize if this question has been discussed or if the answer would be apparent within the software: I’m at work and only have access to my phone.
    Is it possible to graph velocity and acceleration in the software? I’m just looking to do a little bit of design investigation.
    Thank you!
  9. hexpod
    berlin
    7,864Coins
    DC motor, 6DOF
    I believe any value can be displayed on the graph including entry accels and velocities coming from games
  10. FargusFaustmeister
    93Coins
    Thank you!
