SimTools v3 Public Beta
  1. vistol5100
    vistol5100 New Member
    184Coins
    Hi everyone,
    I’ve previously posted about this, but I’m still struggling to figure out if the issue lies with the SimTools plugin or a general incompatibility with F1 25.
    My motion rig is currently unplayable due to chaotic movements. Even when the game is paused, the actuators continue to move as if they are receiving 'dirty telemetry' or constant noise. Since F1 25 has native support for D-Box (which also uses a 4-actuator setup like mine), I’m confused as to why I can't get a clean signal.
    I’m attaching my current configuration and a GIF showing how the telemetry remains active/erratic even in the menus. I’ve tried to fix this by increasing deadzones and raising the Min/Max values in the Tuning Center, but this completely ruins the immersion; the rig feels 'dead' on track, only providing the occasional jolt.
    You can find my initial troubleshooting thread here: https://www.xsimulator.net/communit...sues-on-4-actuator-d-mover.19924/#post-260835 109884 109885 109886
    Is anyone else experiencing this with F1 25? I’m trying to determine if this is a plugin bug or something specific to my setup, especially since Assetto Corsa, iRacing, and Project Cars all work flawlessly.
    Any help or insight would be greatly appreciated!
  2. Giorgio73
    Giorgio73 Alluminium rig with prosimu 3dof kit
    Plc enginer
    Italy,Varese
    846Coins
    3DOF, SCN6
    TITELE: SIMTOOLS V3 CLOSE WHEN IRACING TRACK SERVER START
    Hi guys,
    I've been having a problem with SimTool 3 and iRacing for about a couple of weeks.
    The problem is this:
    When I start a race server, a practice server, or even a test drive, the SimTool application closes automatically, resulting in the dynamics system not working.
    If I restart SimTool, the application starts and the movement system works properly.
    In detail, what happens is this:
    - I start the PC
    - I start SimTool
    - I start SimPro by simagic
    - I start SimHub
    - I start iRacing
    - I select the server to drive
    - the iRacing server starts
    - the car is on the track and the movement system works.
    PROBLEM
    - I finish driving and exit the server
    - I choose another server and start it
    - Once the server is started, the SimTool application closes automatically and the movement system doesn't work
    - I'm forced to start the SimTool application and everything starts working correctly again.
    Every time I exit one server and enter another, I have this problem.
    I've also noticed this situation:
    - The iRacing server is active with the car on the track and the dynamics system working correctly.
    - I press the STOP button on the dynamics system in the SimTool app, the dynamics system stops.
    - I press the PLAY button on the dynamics system in the SimTool app, the dynamics system starts for a moment and then the application closes automatically.
    The dynamics system stops.
    Before a couple of weeks ago, everything was working correctly.
    I haven't had any Windows updates recently.
    Simtool 3 is up to date.
    The operating system is Windows 11 Home.
    My iRacing account is NOT through Steam.
    Does anyone have a solution to this problem?
    Do you need more information?
    Thanks everyone.
  3. Giorgio73
    Plc enginer
    Italy,Varese
    846Coins
    3DOF, SCN6
    Problem solved by new plug in in date 16/02/2026
    Install new plug in and restart the pc
    The problem is solved
    Thanks a lot to the simtool team
  4. toomanywires
    toomanywires New Member
    6Coins
    Hi @yobuddy after the Assetto Corsa EVO 0.6 update I'm no longer able to see telemetry and not getting motion for the simtools V3 plugin for Assetto Corsa Evo. Not sure what Kunos changed but can you take a look?
    Appreciate you!
    • Agree Agree x 3
  5. horyoryo
    horyoryo New Member
    - 25Coins
    The Assetto Corsa EVO 0.6 update works with the SIMHUB update, but when I tried it, it was too rough and didn't work. It felt like it might break my SIM. I want to run it with simtools V3, so I really hope they update the plugin soon. I'm really looking forward to it.
  6. horyoryo
    horyoryo New Member
    - 25Coins
    I'd like to be able to assign keys to simtools V3. Is it difficult to control the start and end of the operation, as well as the intensity?
  7. pikky
    pikky New Member Gold Contributor
    18Coins
  8. Ralf Nass
    Ralf Nass New Member
    31Coins
    Motion platform
    Hi, has anyone managed to get their motion rig working with Assetto Corsa EVO after last week's 0.6 update? Is anyone currently working on updating the SimTools V3 plugin or I need to move to another SW? Thanks for your support in advance
    154,774Coins
    +11,202 / 57 / -2
    Please see earlier comments onward, as clearly Kunos change something that broke the plugin and that has already been reported:
  10. horyoryo
    horyoryo New Member
    - 25Coins
  11. lxyl
    lxyl New Member
    Saturday
    34Coins
    Please help
    After updating simtools iracing plugin to the latest version, if I start simtools before the first time I start iracing session after booting, simtools can detect iracing UI start, but simtools and simhub and iracing manager etc. will get no telemetry data from the game, and if I start simtools after I have started iracing session, telemetry for these apps will work fine.
  12. Falconitage
    Falconitage New Member
    simracing
    11Coins
    nobody to repair Assetto Corsa Evo plugin for simtools 3 ?
    that would be great !
  13. Marc Fdx
    Marc Fdx New Member
    64Coins
    I don't maintain the AC Evo plugin, but it seems that the only step to take in the source code is to replace the names of the memory map files (mmf) it connects to.
    Old names: "Local\\acpmf_physics", "Local\\acpmf_graphics"
    New names: "Local\\acevo_pmf_physics", "Local\\acevo_pmf_graphics"
  14. Micael Johannssen
    Micael Johannssen New Member
    Yesterday
    16Coins
    2DOF, SCN6
    Hello, where do I find this to replace old with new?
    154,774Coins
    +11,202 / 57 / -2
    When the plugin is updated it will be where it already is, in the Plugin Repository.
    For now an update is pending SimTools devs allocating time to do that update.
  16. vistol5100
    184Coins
    Hi everyone!
    I managed to fix the Assetto Corsa EVO plugin by updating the memory mapped file names. Big thanks to Marc Fdx for providing the correct info on the new memory names and to Gemini AI for guiding me through the decompilation and editing process.
    I’m not a programmer, so it took some work to figure out how to use dnSpy and fix the compilation errors, but it's finally working!
    I'm sharing this with the community to help everyone get back on track. If you find this useful and would like to help me out with some coins, I’d really appreciate it! I’m currently trying to save up enough to download another plugin I need for my rig.
    Hope you enjoy it!
  17. pikky
    18Coins
    Thank you very much. It worked great!
