Motor Loss of Traction Reversing Direction
Discussion in 'DIY Motion Simulator Projects' started by Nailson Roveta, Apr 18, 2026.
  1. Nailson Roveta
    Nailson Roveta Nailson
    Retiree
    Serra, Espírito Santo, Brazil
    103Coins
    Hi everyone!
    Has anyone else experienced this situation? I'm asking before I start changing the driver/Arduino. Something curious has started happening in my cockpit; intermittently, when I turn on the cockpit, the motor on the "loss of traction" axis reverses its direction of rotation. I need to reverse the motor's power supply wires, and it works OK. After a while, it reverses again, and I need to reverse the motor wires again. Of course, when reversing, I need to set it in SIMTOOLS. I use a BTS7970 43A driver and three motors on one Arduino (the seatbelt controls are on another Arduino). NOTE: Only the motor with the loss of traction exhibits this behavior.
    Thank you for your help.
  2. Jon Amico
    Jon Amico Active Member Gold Contributor
    573Coins
    Just a guess.... Check to make sure in Sim Tools Game engine, Axis Assignments that the Game List didnt reset back to default if you have a saved profile..
    Every once in a while mine goes back to Default for some reason. I had to match my Default settings to my Iracing Settings because it kept changing to Default. I had backward motor issues as well and this happening didn't help While I was trouble shooting..
    So maybe the Direction of that motor is different in Default setting vs. Maybe a Game Settings you saved for Need For Speed or Iracing or whatever..
    Good Luck!
  3. Nailson Roveta
    Retiree
    103Coins
    That's not it, because every time it reverses direction I need to switch the wires so that the system recognizes the information from the AS5600 (sensor).
    I made a change here that seems to have solved it. I'll wait a little longer and if it works I'll share it here in the group. But even so, thank you very much for your tip/help.
  4. Erik Green
    Erik Green Member
    487Coins
    Are you using an Motion4Sim controller? I've had the same thing happen on one motor of my system. Only cure was replaced the M4S controller.
  5. Nailson Roveta
    Retiree
    103Coins
    Hi everyone!
    I managed to solve it. After some measurements with the multimeter, I decided to redo the connector that linked the Arduino wires to the IBT driver. Now it's working perfectly again.
    Thank you and have a great week.
