FlyPT Mover 3.7.0.26
  1. pmvcda
    16,036Coins
    You are the Legend!
    Welcome back.
    The sliders are locked when you have a source connected. This happens in poses for example.
    Any help needed, just ask.
    I added so many new things that bugs are everywhere... I will squash them with time.
    If you want to try something really new, look at Midi devices with In/Out. You can assign the controls to mover controls (and filters also) and adjust parameters live. Midi with In/Out can take the values in the setup, so for example, you load a setup and the buttons rotate/slide to the values set on that setup. Neat when you are on the rig and want just some knobs.
    • Friendly Friendly x 2
  2. SilentChill
    20,668Coins
    Hi @pmvcda
    No sources are in Mover I removed the completely and I still cant use the slider to move my belts and same with wind ??
  3. SilentChill
    20,668Coins
    Moving the slider does not alter any values at the bottom of the window
  4. pmvcda
    16,036Coins
    I have to check it, the values should change with the slider
  5. pmvcda
    16,036Coins
    Mover 3.7.0.24
    Release notes for 3.7.0.24 (27-04-2026)
    General:
    Solved bug: In CHK the hot control was not correctly saved
    Solved bug: In Midi some hot controls where ignored because of test code
    Solved bug: Virtual Midi should be back (disapeared in last build)
    Some optimizations in the code for speed a bit everywhere
    Directs:
    Solved bug: Where slider was ignored when we had no connected sources
    Sources:
    Updated custom UDP source, now with all the matrixes and quaternions included (think they are correct)
    The coordinate systems are converted to Mover coordinate system, so you should specify the correct one
    Next step is to test this better and pass all that to MMF and HOOKS custom sources
    Download here: https://github.com/FlyPTMover/Releases/raw/refs/heads/main/Mover 3.7.0.24 BETA.zip
  6. SilentChill
    20,668Coins
    Nice 1 thx dude :D
    Sliders work in the Directs for the Belts and the Wind however the sliders still don't do anything in the BassShakers
  7. SilentChill
    20,668Coins
    Does OVRMC still work with the new Mover as I cant seem to get it to see the tracker. I have had to use OASIS driver for my Reverb G2 and a few games wont work with OpenXR using open composite.
    Jeez I been out the game far too long .............
  8. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,900Coins
    DC motor, 6DOF
    Also got angry about G2 getting obsolete. Went for Pimax micro-oled.
  9. JCM
    JCM New Member
    131Coins
    Epic release with so many new features! Thank you so much @pmvcda for this
  10. SilentChill
    20,668Coins
    @Wagnard @pmvcda do you know if Mover 3.7 works with OVRMC as I cant get it to pickup the virtual tracker only the controllers show up in the overlay as reference trackers.
  11. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,385Coins
    @SilentChill
    Sounds like you forgot to install this :
    https://ovrmc.dschadu.de/en/vt_flyptmover
    I didn't not try Mover 3.7 with it yet but since you are not getting the virtual tracker in the overlay, this is usually because you don't have the virtual tracker installed.
  12. SilentChill
    20,668Coins
    Thanks @Wagnard !! I will give it a try, I have just got Assetto Corsa working by copying the openvr_api manually into the game folder and OXRMC is working, it would be easier for OVRMC to work as its all native to steam vr .
    Will let you know how I get on , thanks again
  13. Dicky
    Dicky New Member
    88Coins
    Good evening...I started the project for 2dof, to be able to use in MSFS2020. I have reached the point of configuring with FlyPt mover. I can't figure out how I should configure it. Could you give me some advice? Thank you
  14. Erik Green
    Erik Green Member
    487Coins
    Anyone else getting spikes/noise in ACEvo using Mover 3.7? All other games are quiet for me but when connected to EVO my Motion4Sim driven 3 rig actuators jump slightly from the transients. I also have 4 actuators that are directs and they don't feel like they have transients but I cannot verify from feel alone since they have 15 and 25 to 1 gearboxes. The 3 footed rig actuators are directly driven ball screws.
  15. Erik Green
    Erik Green Member
    487Coins
    Otherwise FlyPT Mover 3.7.... is working perfectly.
  16. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    iOS users who want to control Mover settings remotely for free can try ‎MIDI Designer Pro X‑App – App Store The full version is expensive, but the free one already offers plenty of amazing functionality.
    There are probably good Android solutions too, but I don’t have a device to test them.
    To complete the setup on Windows side, you’ll need:
    - Over-The-Network Midi driver rtpMIDI | Tobias Erichsen (in some cases firewall exception might be needed for "Bonjour" services) and
    - Virtual midi port for ex: SBVMIDI: Springbeats Virtual MIDI driver for Windows®
    Additional routing software like MIDI-OX can also be used if someone wants to link and share commands between several MIDI devices and mover in any direction.
    Everything is pretty straightforward on the Mover side, although filters values need to be scaled through the REMAP -> VARIABLE functionality.
    Huuuuuuuuge thanks to the developer for bidirectional MIDI support (99% ready), which opens new horizons for controlling and fine-tuning motion settings.
    Cheers
  17. SilentChill
    20,668Coins
    Would I be able to use https://www.touch-portal.com/ as thats what I have setup on an old iPad at the moment ?
  18. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
  19. pmvcda
    16,036Coins
    EDIT
    Im wrong, i meant touchosc not touch portal.
    Works, but resolution is 7 bits. You can try using a fader with 14 bits, but i was not able to make it always work in touch.
    The ios one can use nrpn with 14 bits giving way more resolution
    For now im using the roto control wich is pretty amazing, but expensive. Its bidirectional and cool to see controls moving physically when you load a setu or change a value in the Mover UI.
    Need to document this feature better.
  20. DEMONx
    DEMONx New Member
    183Coins
    3DOF, Motion platform
    Epic Roller coasters permanently gone or will back?
