Assetto Corsa EVO 0.6 SimTools v3 Plugin Fix - Working 100%
Discussion in 'Assetto Corsa' started by vistol5100, Apr 28, 2026.
  1. vistol5100
    vistol5100 New Member
    395Coins
    Hi everyone,
    I’m posting this in a separate thread to make it more visible for everyone looking for a solution. As many of you know, the previous plugin stopped working after the Assetto Corsa EVO v0.6 update.
    I’ve managed to fix it by updating the memory mapped file names (Physics and Graphics) so SimTools 3 can now receive telemetry correctly again. I’m not a professional programmer, but I put in the work to get my rig moving and I want to share the fix with the community.
    How to install:
    1. IMPORTANT: Delete the previous Assetto Corsa EVO plugin from SimTools before proceeding.
    2. Download the attached file.
    3. Drag and drop it into SimTools 3.
    4. Enjoy!
    If this fix helps you get back on track and you have some spare coins to share, I would really appreciate it! I’m currently saving up for another plugin I need
    • Winner Winner x 3
  2. Tintin Boulsard
    Tintin Boulsard Member
    199Coins
    3DOF, Arduino
    Thank you so much. It works like a charm !
  3. getupaaa
    getupaaa New Member Gold Contributor
    96Coins
    Hi, it doesn't work for me. Should I unzip the file first, or did I put the plugin in the wrong folder? Could you help me? THANKS.
  4. Tintin Boulsard
    199Coins
    3DOF, Arduino
    You need to uninstall the official plugin and then drag the ZIP file to the Simtools home page.
    Tintin
  5. getupaaa
    96Coins
    Okay, I did as you said and it works perfectly. Thank you so much for your help, it's great!:thumbs
