Tutorial SimTools v3 - RPM Dash Example (with Arduino Sketch)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Apr 26, 2023.
  1. RJ Stausebach
    RJ Stausebach Member Gold Contributor
    Ireland
    315Coins
    :thumbs
    Much appreciated!:thumbs
  2. Horseweed
    Horseweed New Member
    Student/ME
    Georgia, USA
    74Coins
    4DOF
    Hey, thanks for putting in the work to show how this is done. I have a couple of questions
    1: I’d like to set up a few blue lights just as a shift indicator, instead of ramping LED’s how would I change the code to accept this change?
    2: Does the arduino have to be a UNO? I’d like to use a micro instead so it uses less space.
    Thanks in advance!
  3. yobuddy
    51,773Coins
    You would need to edit the logic in the provided sketch, I can peek at it more if you need help.
    It should work on any of them really, but you may need to change the pin assignments the led strip is connected to depending on the Arduino used.
    Take care!
  4. Josemanuelrm
    Josemanuelrm New Member
    valencia
    65Coins
    Hi!
    I'm finishing the project, but if I don't enter anything in the dash, the rpms appear in SimTools. However, if I enter the command
    GetBits 0 9000 8 b
    the pencil turns green, but
    I get a hash # or symbols.
    If I delete it, the pencil turns red, but the rpms appear.
    And the LEDs don't work.
  5. simuaxis
    simuaxis New Member
    - 8Coins
    2DOF, 3DOF
    I couldn't understand why I got such an error
    154,831Coins
    +11,227 / 57 / -2
    In the Arduino IDE, select "Manage Libraries..." from the Sketch menu.
    Search for 'FastLED' and install the latest version.
  7. simuaxis
    simuaxis New Member
    - 8Coins
    2DOF, 3DOF
    Thank you very much.
