NEW ACTUATORS
Discussion in 'DIY Motion Simulator Projects' started by lotada, Oct 1, 2010.
  1. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
  2. Frakk
    Frakk Active Member
    328Coins
    What are you talking about?
    what is best parameters for enough movement and speed reactions in cockpit?
    What is your cockpit?
    Is it a simple moving chair, or a full Cessna body? If you don't give any information to us, how can we help you?
  3. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
    i would like to make 2dof movemne tplatform.. but there is problem with lot prices for gear and frequency converter. so i would like to begin with simply chairr moving only for rfactor. will be enough the wipper motor for this type of simulator?
  4. Frakk
    Frakk Active Member
    328Coins
    I ask you kindly to post here instead of PM or email, other members will be able to benefit this way.
    There are a lot of projects using wiper motors, look around.
    Also see this thread for a controller: viewtopic.php?f=25&t=2697&p=26518&hilit=#26518
    And why is this thread called NEW ACTUATORS? I don't see new actuators anywhere..
  5. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
    sorry i forgot to add link.. i did edit my post.
  6. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
    yeah i did .It seems that it is not enough. what is at all the SCN 5? it is linear actuator with integrated encoder? it isnt any alternate model all over the world?
  7. RaceRay
    Hamburg, Germany
    23,877Coins
    I think the max position outputs are only the maximum values the integrated controller is able to store in memory and to control run one by one independent from any external control unit e.g., a PC. ?!?
    They write, the resolution and accuracy is 0,05mm
    @lotada, i am curious about pricing for a actuator in comprehension to one of the scn5 with similar specs (150mm stroke - 10Kg force - speed 400mm/s) If you got a price, please let us know.
    BR
    René
  8. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
