Tutorial How to convert your Frex SCM to SimTools - Updated
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MasterYoda, Feb 21, 2009.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Hi guys, i' new here, and i want to covert my scm to x-sim....
    This is my simulator:
    http://www.youtube.com/watch?v=pleP-YsYI30
    Is this any good?>
    https://www.conik.biz/webwinkel/:///Ser ... -isolated/
    EDIT: i found the same as masteryoda in my country :)
    http://www.antratek.nl/USB-RS485.html (most below)
    If i understand right, i have to buy this (times 2), do some wiring and then install the software right>? or do i have to purchase some other stuff?
    Do any of you guys with the frex convertion tried msflightsim? and will RBR ever work with x-Sim?
    Thanx in advance...
    EDIT: I found the time to read as much as possible in these forums, and i think i get it, now i have to wait for the converters to arrive, i will post some pics/vids when its working :)
    Rob
    :hi:
  2. splendiddd
    CCTV security
    Netherlands
    813Coins
    Ps: Eric (masteryoda) how did you do that with NoLimits Roller Coaster Simulator? capture its POV?
    I see no plugin for it i the download section....
    thats cool mate..... 8)
    EDIT:
    I got it al figured out thanks guys, for tis great software!
    :clap:
  3. Gilly
    Gilly New Member
    Derbyshire, England
    540Coins
    Hi Guys new here ;)
    How the hell have you kept this place a secret from me? I must live a sheltered life.
    Thanks to njracer who told me about this place, many thanks! :thbup:
    I have just about got fed up with Frex. I have just bought a new PC with 64bit Win7 for which Frex have still not produced a driver. So my first question is will the software and hardware you are talking about here be compatible.
  4. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Just for the records...
    So, I recently decided to install Frex boxes back... It is being a while I am using x-Sim and didn't remember anymore how good or bad Frex control was...
    In a single world:
    Disappointing!
    No matter which settings you use on their sw, the movement is so jerky and rough, that it is not even possible to make a comparison!
    They use only accel, nothing more, as the ranges are not properly adjusted by car/track, it is really a caveman control thing...
    I can say you don't need an advanced profile to beat Frex software, anything simple with accel, pitch and roll and you beat that thing big time!
    All features x-Sim give us to fine tune the movement, control math, actuators speed and accel. are just AMAZING! We should be really thankful to SirNoname for this SPECTACULAR software he give us for free.
    It beats all these expensive commercial solutions by so far that nobody stands even to be worth of comparison.
    So, whoever hasn't converted their SCM to x-Sim yet, is living in the past and dark XV century... That is the best analogy I can make! LOL
    Cheers.
    MY
  5. splendiddd
    CCTV security
    Netherlands
    813Coins
    And...did Dirt2 work with the crappy frex software on your system?
  6. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Nope... It is necessary to edit the XML to 127.0.0.1 in the same way, which makes the game CTD.
    BTW, I saw a video of their movement... Man, that looks like no sense at all... :-/
  7. splendiddd
    CCTV security
    Netherlands
    813Coins
    Lol...another reason for using X-Sim!
  8. danr
    danr New Member
    0Coins
    HI,
    I need the cables to convert from Frex 100mm scn 5 to Devantech USB-RS485 serial interface.
    I think after reading other posts that Frex has a pinout for cables different from oem.
    Please let me know asap.
    I will move forward with this info.
    Dan R
    NJ USA
  9. TTRacing
    TTRacing New Member
    Spain
    - 10Coins
    Hi all,
    We have 2 x top-end Frex systems, neither of which work! We have just coughed up 300€ to send back one set of motion/base controllers to Japan and have them fixed after they lasted about 4 hours (other set have never worked). Virtually given up on ever getting any sensible support from them so wonder if this might be our saviour!
    I´ve read what I can and am I right in thinking that with a download, some setup and the purchase of something along the lines of this USB->RS485 converter we could get it all up and running again?
    Any help or nudging into the right general direction of products/guides would be most gratefully received as I've aged about 20 years since taking on the role of getting it all working :(
  10. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Welcome to the team, TT!
    Stop wasting time and money with Frex shitty support.
    They are not worth our money.
    You can get much better results with x-Sim, much more possibilities too.
    Read my guide (first post) thoroughly, all info you need to make this work is there.
    If you have questions let us know.
    Cheers,
    MY
  11. TTRacing
    TTRacing New Member
    Spain
    - 10Coins
    Many thanks MY!
    We are committed in so much that we have invested heavily (2m Yen - before my time unfortunately!) in their gear initially. My goal is to get something up and running quickly so we can use them as demo units to sell the concept of full motion simulators and then resell something high-end along the lines of the CXC or similar.
    Have read the guide, unfortunately most of the links to USB-RS485 converters are dead so was wondering if the item I linked to would work or not? PCs are running W7 and rFactor but could downgrade if required
  12. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Ok! I see you problem now, that store doesn't sell these adapters anymore.
    However, a quick Google search gave me some other stores selling them:
    http://www.robotshop.com/ca/devantech-u ... rface.html
    http://www.hvwtech.com/products_view.asp?ProductID=949
    http://www.acroname.com/robotics/parts/ ... RS485.html
    There is also a link from x-Sim wiki with several other options.
    I would recommend you to search thru the projects here and see which adapters are mostly used.
    http://www.x-simulator.de/wiki/SCN5_com ... converters
    If you are going to sell CXC products, I am sure Chris will be glad to help you make your sim motion work, too.
    Cheers,
    MY
  13. TTRacing
    TTRacing New Member
    Spain
    - 10Coins
    Already talking to Chris! Trying to get over to sunny CA for a demo if we can raise some cash getting these damn Frex systems fixed!
    The link I gave was to the people that supplied the datasheet on the converter that is linked to in the wiki and looks identical to those you've posted so I´m guessing it's going to be OK? Would rather order from Europe if possible, makes life cheaper and easier ime!
  14. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Yeap! Seems to be the same product!
  15. TTRacing
    TTRacing New Member
    Spain
    - 10Coins
    I assume these converters replace both the useless simcon boxes? If so how would the SimConMETER that we also have work?
  16. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Will not work directly. You will have to make another interface for it.
    Or sell the shit on eBay and buy something better!
  17. TTRacing
    TTRacing New Member
    Spain
    - 10Coins
  18. TTRacing
    TTRacing New Member
    Spain
    - 10Coins
    Everything bought, changed and latest versions installed (well apart from the Configure your SCN5 Plugin settings inside the Profiler 2. which doesn't seem to exist in the same guise anymore) so thanks a million for the guide!
    I'm also using SimXperience Commander which gave me a real leg up the ladder and everything appears to work.. kind of! In rFactor I'm getting great acceleration and braking movement but seemingly no left and right, is this likely to be something stupid I've missed or do I need to delve even further into all the settings?
  19. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Good news.
    1. Send me screen shots of the latest plugin settings and I update the tutorial.
    2. Maybe it is a matter of design differences, Frex actuator positions are too close to the center, while SimXperience is wide, at correct angle... But, this can all be tweaked on the profile to your taste. That is the beauty of x-Sim...
  20. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hi , I was reding this post and have a question about the wiring
    the wiring of these japenese actuator are they the same as their north american conterpart from Mirai
    if yes , what is the difference ?
