problem with fan
Discussion in 'DIY Motion Simulator Projects' started by vulbas, Nov 9, 2010.
  1. vulbas
    vulbas Active Member
    france
    1,102Coins
    AC motor, 6DOF
    hello,
    j'utilise des ventilateurs brancher sur une vm110 avec une interface
    le probleme c'est que le voltage demarre directement à 7v
    je ne sais pas comment faire avec x-sim pour que ça demarre à 0v
    avec le logiciel de la K8055 ça demarre bien à 0v
    ps: l'effet est inversé car j'utilise un tip120 au lieu d'un tip125
    merci de votre aide.
    I use the fan connected to a VM110 with an interface
    the problem is that the voltage starts directly at 7v
    I do not know what to do with x-sim so that it starts at 0v
    with the software for the K8055 it starts well 0v
    ps: the effect is reversed because I use a TIP120 instead of tip125
    thank you for your help.
    http://www.youtube.com/watch?v=sI19OIHLSmQ
  2. Frakk
    Frakk Active Member
    328Coins
    What happens when you adjust the Calibration offset of this axis?
  3. vulbas
    france
    1,102Coins
    AC motor, 6DOF
    c'est pareil, ça demarre toujours à 7v. j'ai aussi testé gtr2 et c'est pareil
    is the same, it always starts at 7v. I also tested GTR2 and so is
  4. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    make on number 1 in your profil velue 57 (engine round) with min 1 and max 100 than you must
    set the right invert, you must test both sides.with 100 % and with the right invert you start by 0 volt.x.sim are can go + and - but you want only +. the blue slider in the sender math setup
    must start on 0 now you see 50 percent from the blue slider.
  5. vulbas
    france
    1,102Coins
    AC motor, 6DOF
    it does not work. it always starts at 7v soon as it accelerates. i don't understend
  6. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    you have on your velue 56 overwride result velue,but you must make add result velue.on all effects.
  7. vulbas
    france
    1,102Coins
    AC motor, 6DOF
    I tested but it is the same.
    what is the problem, I do not know
  8. vulbas
    france
    1,102Coins
    AC motor, 6DOF
    thank you thank you and thank you nima for your help :cheers: :cheers: :yes: :thx: :thx:
    i try an another hbridge
