SCN5 100mm simple profile
Discussion in 'Archived information' started by leonpo, Sep 25, 2010.
  1. leonpo
    leonpo New Member
    - 25Coins
    Please see attached simple profile for SNC5 100mm
    speed and accel: 16,000/400
    Leon
    Leon F1 2010.rn2
  2. Fahim
    Fahim Member
    553Coins
    The profile works. Thanks for this.
    Is there anyway to make it less travel?
    I went to the math setup and changed the percent limiter to only 15 and the travel was same.
    Thanks,
  3. leonpo
    leonpo New Member
    - 25Coins
    If you want less travel, then it is better to increase the value of math line. It will generate for the same value from the simulator less physical travel.
    Leon
