Forum search function offline?
Discussion in 'Forum and Website' started by egoexpress, Dec 13, 2010.
Does the forum search function work fine at your side?
  1. Yes, there are no problems!
    15 vote(s)
    22.1%
  2. Sometimes there are problems which tell me to try again later!
    27 vote(s)
    39.7%
  3. Does mostly not work for me!
    26 vote(s)
    38.2%
  1. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    As far as I know, the search function gets deactivated, if the server load is high.
    I guess the server may become increasingly unable to handle the traffic.
    X-Sim forum page load takes quite long some times, also.
    regards
  2. eaorobbie
    20,502Coins
    only problem i've had was aboat a week ago tring to sumbit a post sometimes having to hit the button over 15 times to get it to work.
    Seems fine now but.
  3. egoexpress
    422Coins
    I dont know how long it takes until the forum resets the search function after a traffic spike.
    Or is it the video bar, that causes overload?
  4. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    I have search problems constantly, and most of the time I'm the only member online :)
    Before becoming a member I didn't use search, I was reading all posts one by one (didn't know what to search for) :)
    But seriously, there is some kind of problem with search feature that needs to be checked.
  5. RaceRay
    Hamburg, Germany
    23,884Coins
    i am asking our provider about that issue. Hope i will get an answer and solution for it asap.
    Br
    René
  6. Deleted member 4666
    Deleted member 4666
    I'm currently getting errors about not being able to execute SQL queries.
    Code:
    MySQL returned error 1: Can't create/write to file '/tmp/#sql_6d2d_1.MYD' (Errcode: 17) (localhost).
    Seems that there are problems/issues accessing the /tmp filesystem, maybe full? :)
    Bye, buk
    Got that via that link in the wiki:
    http://www.x-simulator.de/wiki/Special: ... umentation
  7. RaceRay
    Hamburg, Germany
    23,884Coins
    I deleted the broken *.MYD file on the tmp filesystem and restarted the apache.
    top | shows me that the mysql daemon got a high payload when browsing the forum and using the search. I check the database next.
  8. RaceRay
    Hamburg, Germany
    23,884Coins
    running like a charm at the moment and the load is down. I also do not recognized ANY failure with the search function the whole day :)
  9. Deleted member 4666
    Deleted member 4666
    Aye, much smoother now.
    I'll keep you updated if I discover more errors. ;)
  10. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Search is smoother here too, but I got some errors loading the home page
  11. Deleted member 4666
    Deleted member 4666
    Maybe you hit the moment the SQL Server wasn't available?
    Currently I'm not able to produce any errors.
  12. bvillersjr
    Ohio, USA
    438Coins
    This has been happening for months, not just on the home page, but also on othere pages too. I'm glad to see that RaceRay is back!!
    BTW - There server should always be available :) Database software should have lock managers to handle far more transactions than X-Sim produces.
  13. RaceRay
    Hamburg, Germany
    23,884Coins
    @Barney Thank you :)
  14. bvillersjr
    Ohio, USA
    438Coins
    I speculate that many people have their browsers open to X-Sim even when they are not looking at it. Each time the Recent Posts section refreshes, I assume it is performing a search.
    Would changing the refresh time of the Recent Posts section of the home page from 1 minute to 5 minutes help until there is a dedicated server?
    BTW - That sounds like a denial of service attack waiting to happen! Perhaps we shouldn't advertise the vulnerability ;D
  15. RaceRay
    Hamburg, Germany
    23,884Coins
    Yea, you´re right about the DDOS vulnerability!
    i already changed the refresh time to 120sec ;)
  16. egoexpress
    422Coins
    Search function does not work for me, still.
    regards
  17. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Most of the time: try in a few minutes
  18. Frakk
    Frakk Active Member
    328Coins
    The SQL errors have disappeared for me. Search function also works. :cheers:
