Arduino and X-Sim
Discussion in 'SimTools compatible interfaces' started by HammerHead, Oct 30, 2010.
  1. Poppius
    Poppius New Member
    0Coins
    Ok, now I got it working like I wanted at this point of my career. :) Only thing which was wrong was test-tablet configuration, where I put max 255 and min 0. In Math setup graph this configuration shows only positive values, and I though it was right. But then I once again read tutorials and there were said that middlepoint is 127 in output... So I conffed test-tablet to max/min 2000 and output 8bit one characer. Then I read that char to unsigned int in Arduino, and it works like I wanted...
    Thanks all! :cheers:
  2. Silly(c)One
    Silly(c)One New Member
    ex-Web & Industrial Dev/Sysadmin
    Brussels, Belgium
    327Coins
    Nice one !
    Please keep us posted with your project :beta:
  3. Nikka93
    Nikka93 New Member
    0Coins
    Hi I am using a Arduino UNO but I cant display RPM.
    In Force Profiler it read the correct value but I don't know how to send it to Arduino.
    I sent the speed value correctly but RPM don't work :?
  4. xeriv
    xeriv New Member
    0Coins
    May i know what i need to put into datapacket part of USO to send the data to arduino uno? ~255~~9~~a01~/S~a01~E ?
    Regarding the coding part, how to split the Serial.read() to control 2 servos?
    myservo.attach(9,10);
    Serial.read(x,y)
    Thank you...
  5. Menix
    Menix Member Gold Contributor
    104Coins
    How do you setup the Arduino Card in Force Profiler?
  6. Frakk
    Frakk Active Member
    328Coins
    You set up Profiler in arduino.. :D
    You have to program arduino to receive data in a certain way, and you have to send this specific data from profiler.
  7. Menix
    104Coins
    oh
    hmm has anybody a ready Sketch for programming Arduino Duemillenove?
    For receiving Data?
    Im totally new in Arduino programming
  8. Frakk
    Frakk Active Member
    328Coins
    If you are new to arduino, wouldn't it be a good idea to learn the basics before you jump into programming and interfacing?
    There are many tutorials and sample programs around.
  9. Menix
    104Coins
    hmm
    means this i have to program evry move from profiler and evry step to Arduino? Or is it only 1 routine to get the data from xsim?
    if its to much to programming Than i will buy a new K8055.
  10. xeriv
    xeriv New Member
    0Coins
    I've used the HammerHead code to programmed the uno...
    S~a01~E for uso...
    the motor keep spinning if stop and it will shaking if i start the profiler...
    i've tried S~a01~~90~(motor spins fast)/S~a01~~1~(motor spins slow)
    i need to know what is the correct format for uso... :sos:
    thank you.
  11. Menix
    104Coins
    any news here with Arduino?
  12. juniou
    juniou New Member
    Brazil
    271Coins
  13. Menix
    104Coins
    very nice.
    can you send me the picture of the profiler setup and the sketch for the arduino please?
  14. juniou
    juniou New Member
    Brazil
    271Coins
    the sketch below, it is not a P.I.D sketch yet, is only a servo-control that drives the motor to value mapped from USO (0-255) 8bit resolution. the sketch has a better perform running in 9600bps, because the Read_Lateral (function) uses delay to wait strings from serial... this code is based on http://roamingdrone.wordpress.com/2008/ ... ntiometer/
    ---------------- sketch begin --------------------------
    #define MOTOR_EN_PIN 6
    #define MOTOR_RT_PIN 2
    #define MOTOR_LT_PIN 3
    #define MOTOR_EN_PIN2 9
    #define MOTOR_RT_PIN2 4
    #define MOTOR_LT_PIN2 5
    int motor_speed = 255;
    int motor_cur_pin = MOTOR_RT_PIN;
    int motor_cur_pin2 = MOTOR_RT_PIN2;
    // control indicators
    bool motor_started = false;
    bool first_run = true;
    bool motor_run = false;
    bool motor_started2 = false;
    bool first_run2 = true;
    bool motor_run2 = false;
    int cur_reading = 0;
    int cur_reading2 = 0;
    char kind_of_data;
    int lateral = 0;
    int Lateral1 = 0;
    int Lateral10 = 0;
    int Latreal100 = 0;
    int MAX = 0;
    int MIN = 0;
    int MAX_ant = 0;
    int MIN_ant = 0;
    void setup() {
    Serial.begin(9600);
    // Serial.println(Ready);
    pinMode(MOTOR_EN_PIN, OUTPUT);
    pinMode(MOTOR_EN_PIN2, OUTPUT);
    pinMode(MOTOR_LT_PIN, OUTPUT);
    pinMode(MOTOR_RT_PIN, OUTPUT);
    pinMode(MOTOR_LT_PIN2, OUTPUT);
    pinMode(MOTOR_RT_PIN2, OUTPUT);
    pinMode(A0, INPUT);
    pinMode(A5, INPUT);
    digitalWrite(MOTOR_LT_PIN, LOW);
    digitalWrite(MOTOR_RT_PIN, LOW);
    digitalWrite(MOTOR_LT_PIN2, LOW);
    digitalWrite(MOTOR_RT_PIN2, LOW);
    void loop() {
    //Recebe dados via serial COM
    while(Serial.available() > 0)
    kind_of_data = Serial.read(); //string from USO --> L~a01~ A~a02~ 8bit resolution\decimal output
    if (kind_of_data == 'L' ) Read_Lateral();
    //if (kind_of_data == 'A' ) Read_Aceleracao();
    // ler posicao pot
    cur_reading = analogRead(0);
    cur_reading2 = analogRead(5);
    if( motor_run == true ) {
    if( (motor_cur_pin == MOTOR_RT_PIN && cur_reading >= MAX ) ||
    ( motor_cur_pin == MOTOR_LT_PIN && cur_reading <= MIN ) ) {
    // we've reached our maximum point (don't want to harm our
    // potentiometer
    motor_run = false;
    motor_stop();
    else if( motor_started == false ) {
    analogWrite(motor_cur_pin, motor_speed);
    motor_started = true;
    first_run = true;
    void Read_Lateral(){
    delay(1);
    int Lateral100 = Serial.read()- '0';
    delay(1);
    int Lateral10 = Serial.read()- '0';
    delay(1);
    int Lateral1 = Serial.read()- '0';
    //Verifica se e centena dezena ou decimal... =]
    if (Lateral1 < 0) { lateral = Lateral10 + 10*Lateral100; }
    if (Lateral1 < 0 && Lateral10 < 0) { lateral = Lateral100; }
    if (Lateral100 < 0) { lateral = 127; }
    if (Lateral1 >=0 && Lateral10 >= 0 && Lateral100 >= 0) { lateral = 100*Lateral100+10*Lateral10+Lateral1; }
    // Verifica se o valor anterior é o mesmo ou mudou..
    if (MAX != map(lateral,0,255,100,710)) { MAX = map(lateral,0,255,100,710); }
    if (MIN != map(lateral,0,255,100,710)) { MIN = map(lateral,0,255,100,710); }
    //Seta os limetes para que o motor pare de funcionar..
    if (cur_reading > MAX && map(lateral,0,255,100,710) != MAX_ant) {go_left();} else
    if (cur_reading < MAX && map(lateral,0,255,100,710) != MAX_ant) {go_right();}
    //Atualiza leitura anterior com a atual...
    MAX_ant = MAX;
    MIN_ant = MIN;
    // Serial.println(cur_reading);
    void go_left() {
    digitalWrite(MOTOR_LT_PIN2, HIGH);
    motor_cur_pin = MOTOR_LT_PIN;
    motor_run = true;
    void go_right() {
    digitalWrite(MOTOR_RT_PIN2, HIGH);
    motor_run = true;
    void motor_stop() {
    motor_run = false;
    -- eof ------
    Maybe we can change this to a PID control with this: http://www.arduino.cc/playground/Code/PIDLibrary
    See you
  15. Menix
    104Coins
    thank you very much.
  16. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    great work.. :D
  17. EL-CORAZON
    EL-CORAZON New Member Gold Contributor
    stavanger Norway
    372Coins
    Hi Menix.. have you got it working?
  18. definal
    definal 2DOF Platform
    Bandung
    - 373Coins
    Dear juniou,
    i'm interesting with your project using arduiono + dsmhb, please send us the layout for connecting? and also the complete coding.
    thank you very much
  19. juniou
    juniou New Member
    Brazil
    271Coins
    definal,
    you can define your own layout,
    you just need to declare the variables according to you cable connections... like:
    I sugest you to understand how Dsmhb from Thanos works...
    and check some codes on www.arduino.cc Digital\Analog pins examples...
    If you have some basics of how it works... you can define your own cable pinout between arduino pins and dsmhb pins
    The above code, is the complete sketch, and the cable layout is on the code ;-)
  20. juniou
    juniou New Member
    Brazil
    271Coins
