force profiler - servo controller pololu problem
Discussion in 'SimTools compatible interfaces' started by ch@rles, Jan 6, 2011.
  1. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    Good morning,
    I can not install the com port in force profiler :sos: :sos:
    ( work perfectly with the pololu software)
    Device pach spezified user is blank ???????????????????? :brows:
    Can someone help me
    sorry for my bad english
    Best regards Charles
  2. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Did you try to manually add //./COM6 in the same pull-down menu?
    I have a same controller and i also had to manually add the com port.
  3. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    been investigated but no solution
    thanks
    al uitgetest maar geen oplossing
    bedankt
    Mvg Charles
  4. Frakk
    Frakk Active Member
    328Coins
    You will have to try it like this:
    \\.\COM6 then click Add comport to list
  5. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    hello Frakk
    I have already done, but no success
    :brows: :brows: :brows: :brows:
  6. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    For more information
  7. splendiddd
    CCTV security
    Netherlands
    813Coins
    Try the RegistryCleaner from x-sim (its in the x-sim folder under other stuff) and reinstall the software at latest build.
    Did you try other usb ports and reinstalling the pololu software?
  8. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    Alles uit getest maar verschil :brows:
  9. splendiddd
    CCTV security
    Netherlands
    813Coins
    Ehhh? so it works?
    werkt het nu dan?
  10. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    No it's not working, thanks :cheers:
    Are there not install 1 plugin?
  11. eaorobbie
    20,501Coins
    should work the only thing i can suggest is the port setting in xsim must match serial port setting in pololu software,
    plus sometimes if the pololu software is running xsim cant see the card ?
    Hope this helps as i use pololu products but havent tried this only the Serial rc Controller but some times i have to press my reset switch i wired into it (switch its power on and off to set it to awaiting a command yellow led flashing slowly) onto it as the plugnplay in xsim conflicts with it and sends the card into error and the red led flashes brightly.
    What lights are comming on and how much volts are you feeding her.
    :hi:
  12. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
  13. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    Hi
    After long searching I still can connect between x and the sim card pololu servo controller
    anyone has information I give the information to configure axis I use servos from Hitec HS 422
    I have the following in place but it does not work :blush: :blush:
    simulator starts ~ 255 ~ ~ 8 ~ ~ 0 ~ :thbd:
    axis information ~ 255 ~ ~ 8 ~ ~ ~ a01
    simulator stop ~ 255 ~ ~ 8 ~ ~ 0 ~
    all ideas are welcome :clap:
    best regards Charles
  14. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    yes the problem is solved (~255~~1~~a01~) :D
    where can I find the setting or 180 degrees for 90 servos :sos:
    (my servos are 180 degrees but the movement is 90 degrees)
    sorry for my bad English
  15. eaorobbie
    20,501Coins
    increase ya min and max values in pololu control centre, bit by bit till ya get the range ya need.
