help me with my "DOF simulator, please!!!!
Discussion in 'DIY Motion Simulator Projects' started by gaf00tas, Jan 7, 2011.
  1. gaf00tas
    gaf00tas New Member
    0Coins
    Hi, I have a problem with my 2DOF with wiper motors, when I played 30 minutes, it seems as if they lost power, ie the movement is much smaller.
    you know you can be?
    I have a 12v power supply 20A ebay
    best 2011 for all
  2. eaorobbie
    20,491Coins
    check ya maths plugin for use max. adjustment is unchecked.
    plus a little more information on ya setup would help ya answer. :thbup:
  3. Frakk
    Frakk Active Member
    328Coins
    With this much information you don't even give us the chance to help you...
    Tell us about everything you have and everything you have done to it.
  4. theboemio
    theboemio New Member
    1Coins
    is very difficult to know where the problem if we know nothing about your hardware.
    what type of hardware used for control?
    I spent this error with the high heat source (ATX)
