Bass shaker starting points?
Discussion in 'SimTools compatible interfaces' started by InfinitR, Jan 8, 2011.
  1. InfinitR
    InfinitR New Member
    4Coins
    Hello, I'm looking for ways to use bass shakers with x-sim. Any good starting points? Thanks.
  2. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    Re: Buttkicker controller?
    hi,
    you dont must have a interface x-sim have a bassshaker plugin and give you the
    effects out of the soundcard and you can use volume and frequence with gamedata
    you must have a second soundcard in your gamepc or better a second pc.
  3. Muzza
    Muzza New Member
    Sunshine Coast Australia
    0Coins
    HI Nima,
    Can you explain why a second soundcard is required when using the BassShaker Plugin?
  4. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    In a typical ButtKicker scenario, the signal source for the vibration is the audio from the game.
    X-Sim makes its own outputs to the ButtKicker based on motion data so it needs a second card AFAIK. You wouldn't want to be hearing these outputs.
  5. Papifix
    Papifix Member SimAxe Beta Tester
    im Ruhestand
    Friedberg
    562Coins
    But, if I work with 2 PC over network and each have a soundcard or onboardsound ?
  6. bvillersjr
    Ohio, USA
    438Coins
    Haven't tried this on multiple PC's yet, but I think that the sender from the gaming PC would send the motion data to the profier on the second PC. THe profiler on the second PC would have its own sound card and the BassShaker plugin enabled. This pl;ugin on the second PC would output to the soundcard on the second PC which would be connected to your buttkicker.
  7. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    That's my setup. 2nd PC for motion calculation and also for bass shaker function.
  8. Muzza
    Muzza New Member
    0Coins
    Thanks for the replies, do you think I could run the Basshaker profiles via my onboard audio and my game sounds from my X-Fi on the one PC or would it work better buying a second sound card?
  9. bvillersjr
    Ohio, USA
    438Coins
    I didn't try this myself, but I have been told by someone else who is no longer able to participate here that the bass-shaker plugin has some performance impact on the PC and that it is probably best to run it on a secondary PC.
    That brings me to another question. Has anyone tried the cheap %-$10 USD USB Sound cards with the bass shaker?
  10. OzziV8
    OzziV8 New Member
    Adelaide, Australia
    0Coins
    Hi Muzza,
    I have been reading a lot learning the Lingo in making profiles ect and hope to contribute my understanding soon. However this post has caught my attention. I have the identical setup, ie: onboard sound and a sound card.
    My question is have you been successful with the Bass shakers profile using both sound card and onboard sound.?
    Vito
  11. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    What is the Midi Plugin?
  12. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    I would like to know if you need an Amp to connect the bass shaker to the PC's second soundcard or you can simply plug it like the illustration in the profiler:
    Thx!
    Bleco
  13. BartS
    BartS Member
    417Coins
    I think if the unit has a power jack of its own then it will not need an amp.
  14. Skavage
    Skavage New Member
    - 45Coins
    My $40 usb soundcard works. There is a really nice guide for using X-sim for bass shakers over on the iRacing hardware forums. I'd post it here and give the author credit but I'm not sure if I can upload files here.
  15. bleco
    Montréal, Canada
    258Coins
  16. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    hello i run a basshaker in my single desktop pc. I use the inboard cardsound for sound and a second internal pci express sound card.
    it works pretty good with no impact on performance in my case . the internal pcie card is worth 10 0r 20 bucks (asus dx). i never tried a external card i may try if i find it somewehere in my drawers.
  17. forza4
    forza4 New Member
    356Coins
    SimAxe
    Hi!i just ordered a buttkicker gamer 2 and i am a newbie with all this good soft x-sim,sim tool...i am lost and i need some help please!
    I have a sound blaster x-fi titanium 7.1 and an integrated sound carte,and an other sound card ASUS Xonar dgx in the box!
    What can i do with this please!
    I want to feel all road effect,bumper,...etc ,is it possible with this soft?
    THX!
  18. RacingMat
    21,102Coins
    Not yet with Simtools... but using the sound track is already a very good choice for using your buttkicker :p
  19. SeatTime
    If using the sound track make sure you fit a crossover/filter (if it does not already have one) to filter out the high frequencies (talking/crowd noise etc).
  20. RacingMat
    21,102Coins
    yes, the throne thumper amp has built-in filter: so I supposed gamer2 as well, but it would require to be checked ;-)
