speed/acceleration question
Discussion in 'SimTools compatible interfaces' started by adgun, Jan 15, 2011.
  1. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,790Coins
    hi
    Can anyone tell my whats come first ,speed ore acceleration ?
    fore example a actuator 250mm/sec speed and 0,15G acceleration
    is this race sim material ore only flight sim material?
    best regards ad
  2. Frakk
    Frakk Active Member
    328Coins
    By acceleration you mean torque or thrust? The actual acceleration will greatly depend on the amount of load.
    Acceleration is the cause, speed is the effect. There is no effect without a cause.
    First, you need torque to get things moving. If you don't have torque, you are not going to have speed either.
    It is a balancing act, but you can throw speed out the window if you don't have the acceleration to reach that speed in time.
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,790Coins
    thanks for the reply frakk
    I know about torque and thrust
    It,s a driver question/ the fasted acceleration time from zero to top speed takes 0.187 sec
    this gives 0.15G and scn5 make 1G acceleration unloaded
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,790Coins
    @ frakk
    I,am looking for a cheap 24volt driver 15amp cont 45amp peak with current limmiting
    it,s for a ballscrew actuator with 100kg cont.force and 350kg peak force
    could you point my in the right direction
    regards ad
  5. Frakk
    Frakk Active Member
    328Coins
    You are asking a lot with being cheap, high amps, and current limiting there... :D
    I'm not familiar with such a controller.
    Your google search is just as good as mine.
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,790Coins
    Hi Frakk
    I found a syren 25 amp single channel
    Will it be possible to make youre own adjustable current limmiter and fit it before the driver?
  7. Frakk
    Frakk Active Member
    328Coins
    Anything is possible, but I don't think you want to do that. You would be creating more problems to solve one.
