My turn to make a full motion simulator (planning)
Discussion in 'DIY Motion Simulator Projects' started by MrChaos, Jan 23, 2011.
  1. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    Hi all :)
    Now is the time for me to try making a full motion simulator for my race sims, I've been looking around in here to find a design there would suite me, and as easy to build as possible, when I saw Thanos' design and saw the building materials, I fell in love with it instantly :D
    Now I have been thinking all day about the building materials, because pvc tubes is not that pretty to look at, and my simulator is going to be standing in our living room :)
    After a couple of hours to find some material that was cheap and durable, I thought of the same square aluminium tubes that you use to make aquarium stands out of.
    But will those tubes be durable enough to make a full motion simulator out of ?
    Michael
    Denmark
  2. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    Hello, good to see another scandinavian here, and velcome. If you are going to use your sim in the livingroom and space and design is an issue, I would consider seat mover sfgt-style simulator or something like deriys design (top work at first page) I was also considering joyrider, but it seems to me that most people choose or recomend seat-mover for racing. Some of us are building seat-mover with vipermotors and Thanos electronics (or part of it) and there is also alternative hardware for vipermotors. I think a seat-mover will be faster and easyer to build also. Anyway good luck Michael! :thbup:
    Fred
  3. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    Hi fredspeed
    Yes I have been looking at seatmovers, it's not the space that is the issue here, it's the looks of Thanos' joyrider, it don't really look good in a living room :D
    The reason that I don't want to build a seat mover is, that I wan't to have the same motion as in the joyrider, and I also want to have my 3x19 monitors installed on the simulator and not having them stand on the table, it seams wrong to me that you have a motion on your seat and you monitor just stands still, because in a real racing car you are strapped tight to your seat and you follow the movement of the car, so you vision is almost the same on straights and turns.
    But I haven't tried a simulator before, so I'm only guess that it would be like that. :)
    But could I use the aluminium tubes ? :)
  4. fredspeed
    Northern Norway
    418Coins
    I have not tried one either, that is the reason I listen to what people are experiencing here at the forum. I also like the thought of the g-forces in joyrider, but i understand the fast tensions you feel in a racing car is easyer to get from a seat-mover. have never been in a real racing-car either, so its all about imagination anyway :D
  5. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    Hi
    Is there anywhere I can buy all electronics for a joyride or a seatmover simulator, I'm going to use wipermotors.
    I'm not that great at electronics to build my own curcuitboards, and if I should build them my self, then I can't find a complete list of components that I need to build the boards, so if there is you know of a good place to buy the electronics, I would appreciate if you could drop some links here, so that I can start build my simulator :)
    Michael
  6. fredspeed
    Northern Norway
    418Coins
    Let me share my experience: I had no skills in electronics, but desided to try build Thanos boards. The reason for it was that I enjoy doing it myself. I had to use a lot of time, and I am still not shure if I am able to make it work, because there is still some problems to overcome. Therefor I recomend you to study some of the other solutions as pololu or Vellemann, and deside how much of this you want to build yourself. I am pretty sure if I have chosen tex. pololu from the beginnin this would be cheaper for me. I had a lot of cost in shipping, etc. I have used http://www.futurlec.com/ and http://www.digikey.com/ to get my parts. Warnings: Futurlec takes time, and digikey have expensive shipping. Futurlec also made my pcb.
    If you have not alredy, read this topics:
    pololu-jrk-12v12-t2697.html
    k8055-dual-wiper-motor-control-with-variable-speed-t2795.html
    If I where at your stage, I would certainly go for one of these solutions. :yes:
    Fred
  7. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    Hi Fredspeed
    Thanks for your help, I think I'll go with the Jrk 12v12 it seams easier, but can I still use the profiles people in here are making for the games, or do I have to learn how to make those profiles from the start ? :)
  8. fredspeed
    Northern Norway
    418Coins
    There are plugins for the compatible games.They work with Force-sender. in Profiler the profiles is made to fit the hardware (like pololu) and the setup (as joyrider) but also the games to improve the force feedback. I am sure the people using pololu12v12 are willing to share the profiles they use, and you can edit them after your needs. While you are witing for parts it is useful to play around with x-sim sofwware to learn about it. Others might also explain this better than me.
    Fred
  9. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    I have installed x-sim but I can't start it, it says : the requested operation requires elevatition
    I get this message with both Force profiler and Force Sender :(
  10. fredspeed
    Northern Norway
    418Coins
    Do not have the answer for that but: There are different versions of x-sim, and you can try another to see if you get the same problem then. You can post your problem at this topic: x-sim-beta-general-f57.html Be shure to tell what system/platform you are running, then it is easyer to get help. Also read this: how-to-report-bugs-effectively-t1322.html (I have not :lol: )
    Fred
  11. Deleted member 4666
    Deleted member 4666
    You need to run Sender & Profiler with admin-rights. :thbd:
  12. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    Post the version of your operating system and x-sim you're using, and you'll get better answers.
    I think I've had something similar, and I need to use compatibility mode in my Win7 64bit to run x-sim SW.
  13. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    Thank you that helped, so now I can use the program :)
  14. MrChaos
    MrChaos New Member
    Denmark
    333Coins
    I'm also using Win7 64 bit version, but with run as administrator it worked
    I'm using the 10.0.1.2 version :)
    Michael
    Denmark
  15. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Your user account should be an administrator on the PC. Run as Administrator will work, but its annoying to not be able to simply double-click an icon.
  16. Deleted member 4666
    Deleted member 4666
    No!
    Changing permissions for the serial port is/should be the way to go.
  17. bvillersjr
    Ohio, USA
    438Coins
    LOL... Are you going to write the tutorial? The users will need screenshots to be able to follow it too.
  18. Deleted member 4666
    Deleted member 4666
    Will you create the screenshots to remove the latest trojan that came in with the funnyfunny.pps attachment?
