RafBR 2DOF Wiper Motor Cockpit
Discussion in 'DIY Motion Simulator Projects' started by rafael_design, Feb 20, 2011.
  1. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    This monday i'll shop the parts of the Thanos list to begin my first sim.
    Hope i buy the right stuff ;D
    It will be an 2DOF SimforceGT Style Wiper Motor Cockpit.
    My first goal is to make the electronic boards (AMC, H_bridge, LCD) and gather the motors and cables.
    As i will not build the frame at first, it may be the JoyRider in the end.
    See you soon!
    ps. I am using google translate to help me write correctly :cheers:
  2. gsffair
    gsffair New Member
    - 150Coins
    Vai que dá!
    Go for it.
  3. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
  4. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    :hi: prepare your 3 month free time
  5. rafael_design
    Brasil
    328Coins
    Yes, a bit! :blush:
    - In fact i have a lot of delays because:
    I made an working table for this project.
    I etch myself the AMC board and it's my first time!
    I made the holes with a homemade drill.
    I made a kind of exhaust to work with solder.
    The missing parts are on their way, i had to buy them from maybe five different stores and not sure i have all.
    - Progress:
    So the AMC is with +/-80% of components soldered (i hope i made it right!).
    I have three cables done.
    - To do list:
    Tomorow i will etch the H-Bridge, try to drill the holes and solder the components.
    Post some pics.
    I want to make the sketch on 3d.
    So this is it. It is late here now so i won't post the pictures today.
    :cheers:
  6. Kiko Tocci
    Kiko Tocci New Member
    Brazil
    349Coins
    Hi Mario,
    I will trie do do the same simulator then you.
    I'm fron Londrina and have some problens with the parts aslo.
    Soon i will post my progress, for everybody.
    I still reading e learning more about all parts ando configuration.
    I would like to chenge somo expirience with you.
    Can u give me de adress were u buy the electronics?
  7. rafael_design
    Brasil
    328Coins
    Who is Mario? :?
  8. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    Nice job, but you've made two little mistakes :)
    You've etched two wire bridges on board and short-circuited the lines. I hope you saw that and you plan to cut the lines before powering the circuit!!!!!!!
    If you don't understand me, I'll edit your picture to show you.
    EDIT: It should look like this, and you solder the bridge wire from component side to make connection
    BR, Igor
  9. rafael_design
    Brasil
    328Coins
    Thanks Igor!
    :thbup:
    This is the link to the pdf i downloaded.
    download/file.php?id=1024
    It's the sprint layout and as you can see the short circuit is in there.
    Other thing is that parts list asks for:
    1x 10R resistor
    5x 10K resistor
    I found 6x 10K and not the 10R on the layout.
    Now i am going to look my h-bridge that is under water! Later will post more pics of my board with components.
    :cheers:
  10. fermevc
    fermevc Member
    Serbia
    5,956Coins
    You're right for resistors, you need 6 x 10K (10R is wrong)
    In pdf you stated, on first page, all layers are visible, you (and anybody else who will use this file) should toner transfer picture from page 2 (there are no short circuits there) :)
    Later on page 4, you have 3 bridge wires (think of it as double sided pcb). I've missed the 3rd short circuit error on your board :(
    It should be clear for you to find it but I'll post the fixed AMC picture:
    It is slightly different layout from the one you've used, but basically it's same circuit, and part values are correct (I've made my parts list using info from this picture).
    I've made my AMC using this for reference and it is working like a charm (18MHz crystal and FW).
    Notice the colors: GREEN - coper side of PCB, YELLOW - components (silk layer), RED - holes/solder pads and WIRE BRIDGES (component side of pcb)
    I've made a step by ste guide for AMC and HB with all the info and part lists, but it is still waiting for developer review. I'm hoping it will be publish soon.
    If you have any questions, post them.
    BR, Igor
  11. Kiko Tocci
    Brazil
    349Coins
    Sorry Rafael,
    I made a mistake,
    But is for you that i wrote.
    Sorry about my english and the mistake.
    Let's change some ideais about our projects.
    I'm ordering my parts in www.multcomercial.com.br, but thei don't have some of then.
    Where did u buy yours?
  12. rafael_design
    Brasil
    328Coins
  13. rafael_design
    Brasil
    328Coins
    Hi Kiko Tocci!
    Try soldafria.com.br
    They have some but not all of them.
    I hope this week i can gather them all so i can tell you where to find it.
    :cheers:
    RafBR.
  14. fermevc
    fermevc Member
    Serbia
    5,956Coins
    You're right about 3rd short0-circuit, it is well marked on your last picture!
    Just cut the wrong coper lines with sharp knife and you'll be OK.
  15. rafael_design
    Brasil
    328Coins
    Are there any problem if i use 5% tolerance resistors instead of 1%? :?
    I ordered 5% because of some pictures i saw.
    But other pictures show 1% resistors.
    I spilled beer over some components of the AVR! :clap:
    Are they water proof?
    Here is a picture of them.
  16. Kiko Tocci
    Brazil
    349Coins
    Hello Rafael,
    Today I order my part list.
    I have to order in 4 diferent stores but I got everithyng, I guess......rs
    I will open a topic soon.
    stores
    soldafria.com.br
    cinestec.com.br
    compomil.com.br
  17. rafael_design
    Brasil
    328Coins
    About the resistors, you bought 5% or 1%?
  18. rafael_design
    Brasil
    328Coins
    ;D
    Today i finished my second PCB (H-bridge)!
    Here are the pics showing what i could gather until now.
    What is not in these pictures is what i could not put my hands on yet.
  19. fermevc
    fermevc Member
    Serbia
    5,956Coins
    It should work OK with 5% tolerance resistors, but it is advised to use 1% cause they are generally of better production quality. To be sure, measure the values using Ohm-meter just in case.
  20. Kiko Tocci
    Brazil
    349Coins
    I bought booth,
    Some 1% anothers 5%, there any problem to have booth percentages?
