KIKO's Wiper Motor SIM
Discussion in 'DIY Motion Simulator Projects' started by Kiko Tocci, Mar 3, 2011.
  1. Kiko Tocci
    Kiko Tocci New Member
    Brazil
    349Coins
    Hello friends, okay?
    I'll start this topic to show the progress of my simulator and exchange experiences with you.
    I'm starting with the electronic part in which I chose to use the plates AMC and H-Bridge designed by Thanos.
    I have ordered the electronic parts that are starting to arrive and lay-outs and transfer the plates already drilled.
    Not yet defined the model of the cockpit that I use, but I hope all of you suggestions.
    For some time I'm reading and rereading various projects and hopefully get a nice result with all the information that I'm taking the x-sim.
    Sorry for my English, I'm using google to translate.
    Grateful and expect cooperation from all of you.
  2. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
  3. Kiko Tocci
    Brazil
    349Coins
    Rafael, thanks for the tips,
    As I said above, not yet set a model which will use the Cockpit.
    In the first hand was wanting to use the Joyrider, but after reading enough, I thought it better to opt for Simforce.
    But I'm still looking and accepting opinions.
    Regarding the electronics, I am totally a layman and am starting to work with it now.
    I had to learn everything myself, watching videos on youtube but I'm pretty hopeful, because I learned to transfer the circuit, welding and drilling the plates ...... lol
    I'll need much help from everyone here in the forum, but I'm sure I'll get.
    Thank you,
    Kiko
  4. eaorobbie
    20,506Coins
    easier option foe electronics is the pololu jrk12v12s but nil stock till april. just plug-set xsim-play.
  5. Kiko Tocci
    Brazil
    349Coins
    I appreciate the tip above, had already observed this hypothesis, but I'm rather stubborn'll keep more AMC H-Bridge.
    If complicate things, I go to proliferating as Plan B.
    It's always good to have new challenges in life ......... rs
    The night I'll post my first pictures.
    Sheltered
  6. Kiko Tocci
    Brazil
    349Coins
    I've been away for a few days, but now I'm back.
    While I hope the electronics parts arrive, I put a little time in the layout of my simulator.
    I'll post to you the 3D model I'm doing.
    I would like suggestions to further improve my project.
    Go there a few observations:
    1. The screen is removable, and may adjust a monitor or tv of any inch.
    2. Not yet finalized the support gear and keyboard, will be tomorrow.
    3. I wanted to observe more or less, measures and slope of the seat support for engines.
    4. The structure we intend to use is steel, because I want something very sturdy.
    5. I also wanted to observe the action on the seat, steering wheel and pedals.
    6. The wheel will be adjustable in height and depth, and the pedals are adjustable in depth.
    Thankful and a great weekend everyone.
  7. Kiko Tocci
    Brazil
    349Coins
    More posts of the chassis, now on the projection screen.
    I await comments from you.
  8. bsft
    Nice design there! However, wouldn't it be better if the wheel and pedals were part of the motion seat? Just a thought.
  9. Frakk
    Frakk Active Member
    328Coins
    Good job Kikko, I like the front end! When you make the back end, make sure you have different positions to play with and tune the geometry.
    bsft: no, this setup will give better feelings with less amount of work from the motors.
  10. Kiko Tocci
    Brazil
    349Coins
    Thanks friends for the comments above,
    Now I wait to get my electronic components to begin manufacturing the plates, as I said before I will use the model of Tronic.
    I think the principle I have a little difficulty, because my knowledge of electronics is pretty weak, but I'm sure I can, because the way I'm able to count on your help.
    This week more work on the frame design and tune a few items and begin production next week.
    I thought this project and this type of frame, so now I want to adapt SCN5, will it work well with the model I created?
    I also intend to soon make him constant updates as well as purchase equipment ECCI, Rozo wheel, pedals reversed, there of course, goes my imagination.
    I'm excited about the project and hope to count on your help.
    Grateful
    Kiko
  11. Kiko Tocci
    Brazil
    349Coins
    I made some updates to the layout.
    As I said earlier, the wheel would be adjustable in height and depth.
    Note the position of the steering wheel in the picture below.
    The same goes for the pedals, they can be adjusted both in height and in depth.
  12. Kiko Tocci
    Brazil
    349Coins
    I was a little gone, hoping to reach the electronic parts to start making circuit boards.
    Well they came for the most part and now I'm just finishing them.
    The night I'll post some pictures.
    I'm having doubts about the source of energy.
    1. As I read earlier, several people suggested a car battery, what is the correct voltage and amperage to buy?
    Remembering that my engines are 12 volts.
    2. I also need another hint, which use cable to connect the AMC to the computer to program the chip?
    3. One more question, which the potentiometers suitable for my project?
    Grateful and look forward
  13. Kiko Tocci
    Brazil
    349Coins
    Below pictures of the cards I'm doing and I just bought the engines,
    For those who could not even weld, I think I'm doing well ... rs
    After much reading follows from the work, but there are still some parts to arrive.
    I ask for the experts that give a look and tell me if it's alright.
    They can take a look at the weld to see if it also good?
  14. Kiko Tocci
    Brazil
    349Coins
    Here is the latest update of the frame,
    I made some adjustments in overall width, in order to pass through the doors without any problems and also did an update at the seat, where it will be adjusted for height, inclination and depth.
    As I said earlier, this type of frame that I'm doing it can be used either as the GT and Formulas.
    The materials are already purchased and next week start production.
    As for the evolution of production'll post pictures.
      147.6 KB
      785
      157.9 KB
      750
      95.2 KB
      751
      159.9 KB
      774
  15. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    Looking good :thbup:
    Try to remove solder residue (the greasy stuff) from DSMhb board, and you should solder the HB resistors before mounting mosfets (Thanos's advice).
    Keep up the good work :)
  16. Kiko Tocci
    Brazil
    349Coins
    Friends, I have a big problem finding the capacitors 100nf/100volts and 1.2 nf.
    Does it have any other that I can replace?
    The cockpit frame is almost done, and this week put the photos for you guys.
    I await a light from you.
    Grateful
  17. rafael_design
    Brasil
    328Coins
  18. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    nice sketch bro. :hi:
  19. Kiko Tocci
    Brazil
    349Coins
    I was looking for a cable to connect the notebook to the AMC and found this cable with a USB output and one DB9.
    Can you tell me if it will serve to program my board?
      22 KB
      641
  20. rafael_design
    Brasil
    328Coins
    :hi: Kiko!
    I will connect it straight to the motherboard. I bought parts so I can make the cable.
    DB9 (AMC) > IDC 10 com/serial (MB)
    :cheers:
