iracing Star Mazda with Slider - corrects
Discussion in 'X-Sim² profiles' started by Papifix, Mar 4, 2011.
  1. Papifix
    Papifix Member SimAxe Beta Tester
    im Ruhestand
    Friedberg
    562Coins
    Sim: iRacing
    Car: Star Mazda
    Actuator type: SCN5 150mm
    X-Sim version: 2.0.8.9b
    no limiter
    Speed and accel set in Synaptrix
    Thanks Niels, there was a mistake with the slots for Copy and Compine, I have corrected.
    The changes in the minimum to values are also good, the seat some long bunting thereby retrogresses before and. Feels more normal and less like a simulator.
    I have added a little bit more hill, nevertheless, there spa with o blusher gives more pleasure.
    A new version. The first one had a bug with 32. Sorry
    iracing star mazda with slider - v.1.1-.rn2
    Gruss
    Rainer
  2. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    Re: iracing Star Mazda with Slider
    hi,
    the second copy and combine have the number 4 but you must have number 8
  3. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    set 27 brake from min -100 to 10000000 .27 accel min to10000000.and 22 min of 10
    only a idea
  4. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    You should try to add effect 23 for more realism... for me it's a must... but I don't know what it would result without dampers...
    On my sim, I could barely feel any longitural accel and RPM feeling... very low (accel) and null (rpm) feeling..
    Lateral feeling is good,
    Interesting way of creating a profile, keep it up!
    Bleco
  5. Papifix
    im Ruhestand
    Friedberg
    562Coins
    Thanks for the comment.
    It seems to be really indispensable that everybody provides his profiles itself. The ledge are apparently very different and everybody prefers another feeling.
    Rainer
  6. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Thank you so much, this profile is working very well on my simulator.
    I love the way the speed builds up when you start from zero, rather then that the seat goes crazy at very low speed, i mean that this is more realistic in my view!
    Keep up the good work, and i would love to see more profiles from you :happy:
    :cheers:
    Regards,
    Rob
  7. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi papifix
    the velue 32 one side must invert.test with min 100 and max 600000 and with a new slider this is for drift feeling.but i love the aculations feeling.
  8. splendiddd
    CCTV security
    Netherlands
    813Coins
    I am using this profile for most of the IRacing cars, I love the sliders that come with this profile for fast own taste motion...
    Here is a video with this profile on the Riley car in IRacing:
    http://www.youtube.com/watch?v=ueZ7a4cdsN8
    BTW: Remember to load the profile twice if the sliders are only connected on one axis!
    THanks again Papifix!
    Regards
  9. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Thanks a lot, looks promising. DL it and will test it tomorrow. Testdrive Video from spendiddd looks fantastic. So smooooooth
