X-Sim Speed Controlled Fans for Racing
Discussion in 'DIY peripherals' started by splendiddd, Jan 6, 2011.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Hi Guys,
    After NuMcA and SimonME46 had made speed controlled fans i wanted them also on my sim.
    With the help of member Frakk i am now testing the fans and they work flawlessly with X-Sim !
    Parts used:
    - Rechargeable-Sealed-Lead-Acid-Battery-6V-4AH witch is powered with a 7V-2A-AC-DC-Power-AC-adapter.
    - Pololu Micro Maestro 6-Channel USB Servo Controller (Assembled)
    - ATC fuses+holders, Deans and Bullet connectors
    - TURNIGY Basic 25A and a 40A Speed Controller ESC (electronic speed controller)
    - 2x70mm Duct Fan + 3000KV Motor for lipo RC Jet EDF plane (Fans for radio controlled planes)
    When i recieved the hardware from Frakk i made a safety feature on the fans with aluminum tubes and a strong bug-net (believe me, you do NOT want rubble to get in those things, they can rev up to 18000RPM at full power!):
    After this the setup with X-Sim was easy, also the games i tested where Codies games, and they output a high resolution so the airflow is controlled very well (so the 255 is now 8500):
    Here's a short video of the result till now, The air flow power usage of the fans is ONLY 30% :eek:
    http://www.youtube.com/watch?v=Va-nPSm1u9E
    The noise is still a problem, when i go higher then 50% its too loud. Still have to think of something for that. already reduced some by using tubes and placing the fans futher away.
    Please feel free to ask if you guys have any questions or suggestions.
    Again credits go to Frakk for making the hardware for me :D
    :cheers:
  2. benefie
    benefie New Member
    Germany, Hamburg
    1Coins
    Looks very interesting.
    What are the overall cost for the system? And why are you using to different speed controller (for testing purposes?)?
  3. Frakk
    Frakk Active Member
    328Coins
    The over all cost is not the cheapest, but it is definitely easy to set up and it has more than enough power for anyone, even a single fan setup.
    Please note that any of these components can be substituted with others to suite local markets and availability.
    -Battery: http://cgi.ebay.ca/SLA-Sealed-Lead-Acid ... 1506wt_911
    -Charger: http://cgi.ebay.ca/Oriex-27AD-Power-AC- ... 1186wt_911
    -70mm Fan + Motor: http://cgi.ebay.ca/70mm-Duct-Fan-3200KV ... 3132wt_930
    -There is a 90mm version with/without brushless motor for more money.
    -Uni-directional hobby ESC with braking: http://hobbyking.com/hobbyking/store/uh ... oduct=2163
    -Pololu Servo controller: http://www.pololu.com/catalog/product/1350
    -Additional bits and pieces like extension cables, power switch, connectors, etc. are personal preference.
    Over all cost of the 2 fan system is ~200USD with everything shipped separately, depending on the parts used.
    Why 2 speed controller? 1 motor needs 1 speed controller. 2 motors can be set up for sidewinds/differential airflow, and also distribute the wind more evenly.
  4. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Nice project. Thanks for sharing!
    The X-Sim settings screenshots are a little small though.
    Regards
  5. splendiddd
    CCTV security
    Netherlands
    810Coins
    Solved.
    :yes:
  6. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Hi Rob,
    we already talked about your project, but I want to say this here in the official thread once again: GREAT JOB, ROB AND ADAM :clap: !!!
    I'm happy to show this step-by-step-howto on my site as another great DIY-solution and I will build this for my new EVO3 too 8) - I already mounted a big tube few weeks ago...
    Thanks for sharing :cheers: !!!
  7. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Oh dear,...
    Two things to realize in the near Future. With that I am not sure, where to put the tubes. With the triplescreen setup you can only guide the wind from the top or the bottom of the TVs :eek:
    One thing I wanted to add is the air guided out of the outlet. Like the rudder on a model plane steered with an RC servo. So you could realize direction changes of the wind while cornering.
    I like the idea of a rotating platform.
  8. pitstopp
    pitstopp Active Member
    Dortmund
    634Coins
    3DOF, SCN5, SimforceGT
    Hi Rob and Adam,
    really great work!
    I have one question : I own the Fanatec CSP Pedals, there is a build-in vibration Motor on the Brake Pedale . But it only works in combination with the fanatec wheel and only with Rfactor.
    So, ist it possible to use your setup to make the Abs vibration get working with x-sim?
    The motor is USB powered, should i use a battery ?
    The Speed controller will work with 5V?
    I have very low electronic and coding skills!
    Regards
    Kai
  9. pitstopp
    Dortmund
    634Coins
    Hi
    I don´t use the fanatec wheel!
    Is there any software solution for detection of the CSP connected by USB?
  10. splendiddd
    CCTV security
    Netherlands
    810Coins
    I don't think if you guide the air like you mentioned will make much difference, and it would minimize air flow. air is not really that precise...You can better mix the fans in direction for different left/right airflow for sidewinds in the profiler.
    Oh and if you place the tubes around the height of your dash/wheel and point them up a bit like i did, you will get enough air in your face :D
  11. ATSP
    ATSP Member
    Krefeld
    351Coins
    2DOF, Joyrider
    Cool!
    very nice work!
    my next Projekt is born:)
  12. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    great job...think of it long time..
  13. splendiddd
    CCTV security
    Netherlands
    810Coins
    Hi Guys,
    Thanks for all the comments, here is another video, now with a test of Dirt2. Have to say the fans are a lot of fun with Dirt2! adds a lot of immersion :eek:
    http://www.youtube.com/watch?v=GTnYVuCBAJc
    Regards,
    Rob
  14. splendiddd
    CCTV security
    Netherlands
    810Coins
    After upgrade on my rig (New seat, dash etc.) the fan's now also work with Nolimits.
    I used the cheatengine to find the speed values. Uploaded the injectorfile online, search for nolimit.
    Profile is based on Masteryoda's profile:
    AA NOLIMITFAN.rn2
    http://www.youtube.com/watch?v=jCtGh1ODtYU
    Ps: i could not post this in the nolimits profile sub-forum, nor add it to Masteryoda's post....
    More to come ;-)
  15. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
  16. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    superb desktop and tools..
  17. splendiddd
    CCTV security
    Netherlands
    810Coins
    Thanks, here's another video:
    IRacing Star Mazda - Zandvoort 35% Fan power:
    http://www.youtube.com/watch?v=YEjzhIvy2Lc
    :brows:
  18. splendiddd
    CCTV security
    Netherlands
    810Coins
  19. NuMcA_[.gr]
    NuMcA_[.gr] New Member
    3Coins
    Congratulations guys!!
    :clap: Great work!! :clap:
    It looks amazing!
    X-sim project of the year :cheers:
  20. NuMcA_[.gr]
    3Coins
    GREAT job guys!! Very nice project!
