Feedback for me on this POT please
Discussion in 'SimTools compatible interfaces' started by shannonb1, Mar 30, 2011.
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
  2. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  3. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  4. EL-CORAZON
    EL-CORAZON New Member Gold Contributor
    stavanger Norway
    372Coins
    Hi
    I have not tried either of those.. but the first one is plastic type and is more durable when use continuous .and are better built . and I assume much more precise.
  5. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Thanks EL,
    I used the digikey ones in my simulator pedals, very sharp and accurate. I went ahead and ordered the digi. already had one, so well see, not a multi turn but from what i read I dont need that
  6. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    wonder if we can replace classic pot with accelerometer 8)
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Do you think they would be accurate enough for motor positioning? Im not sure that would be a better experience, give it a shot!
  8. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    most of advance project use accelerometer + gyro for accuracy.
    http://www.youtube.com/watch?v=bI06lujiD7E&NR=1&feature=fvwp
    :yes:
  9. Frakk
    Frakk Active Member
    328Coins
    Accelerometers can't be used for position feedback, just think through what would happen... :)
  10. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Should work at least as good as with a thermometer.
    You posted this one day too early :)
    regards
  11. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    frakk: I'm just think of that. if it can be done maybe we can just stick the accelerometer at the bottom of the seat.done. One accelerometer enough for 2 or 3DOF. :D
    egoexpress: :cheers:
  12. egoexpress
    422Coins
    The data from an accelerometer is useless to effectively position an actuator/motor.
    Accelerometers are great to capture g-forces in a real racing car, a plane or a roller coasters. Combined with a video, this data can be used with the X-Sim video plugin.
    But I cant see any purpose for accelerometers as position feedback for actutators/motors.
    Potentiometers, hall sensors, quadrature encoders, = position feedback
    Accelleromters = acceleration feedback
    For motor control you need position feedback
    regards
  13. Frakk
    Frakk Active Member
    328Coins
    What do you think will happen when the controller tries to maintain a constant acceleration?
    Make a video if you try it. ;)
  14. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    I am newbie in this arena,,,not going anywhere without advice from you guys. tilt sensor maybe more suitable rather than accelerometer. I am just thinking about this because too many people including myself have a quite same problem with pots etc. type, size, noise, harness or even gearing.
  15. egoexpress
    422Coins
    You could replace pots with hall sensors. They are pretty accurate and dont wear out
