what is the last version available?
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by AldoZ, Apr 27, 2011.
  1. AldoZ
    AldoZ Member
    Pc Shop
    366Coins
    Hi, what is the last version of X-SIM??..
    I have the X-Sim version 2.1.0.3 but I see that there is the X-Sim 2.0.8.9 and 2.1.0.13 stable *Update 22-02-2010*
    I would to have the white edition but I see that this version is older than the X-Sim version 2.1.0.3!.. right?
    So for the offline use of X-SIM, what is the latest version?
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    2.0.8.9 is the same as 2.1.0.3 as far as what is under the hood. IMHO, 2.0.8.9 (offline version) is far more stable.
  3. AldoZ
    AldoZ Member
    Pc Shop
    366Coins
    mm thanx bvillersjr,
    you say the 2.0.8.9 version is more stable than 2.1.0.3 but so you say that a older version is more stable than the newest??
  4. bvillersjr
    Ohio, USA
    438Coins
    No, the version numbers are no it sync for some reason. 2.0.8.9 is the same as 2.1.0.3.
    2.1.0.3 simply adds some online features that were not stable in many cases. Most users here have 2.0.8.9.
  5. AldoZ
    AldoZ Member
    Pc Shop
    366Coins
    Ah understand! Thx!
  6. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    hmmm I think you are wrong ...
    2.0.8.9 is the same as 2.1.0.13b without the online features...
    2.1.0.3 is a much older release according to the change log...
    Bleco
  7. bvillersjr
    Ohio, USA
    438Coins
    The online and offline version numbers are not in sync. Otherwise they are the same except for the online vs. offline features.
    It is not possible to download the non b version akaik, so I didnt' muddy the water any further. If you want to be technical about it, 2.0.8.9b = 2.1.0.3b - online features that cause instability.
    The post calls them without the b, but the download link includes the b. In any case, what's important is that you don't get the 2.1.0.3 version b or no b :)
    What's different in the change log: x-sim-2-0-8-9-and-2-1-0-13-stable-update-22-02-2010-t2149.html
  8. bleco
    Montréal, Canada
    258Coins
    2.1.0.3 and 2.1.0.13 are two different versions ... 2.1.0.3 is an old release ... There were 9 releases between 2.1.0.3 and 2.1.0.13... Initial post talks about 2.1.0.3 not 2.1.0.13 ...
    2.1.0.13
    - Added: More multiply factors to the Force-Injector
    - Fixed: Force-Injector accepts empty patch notes in online database
    - Fixed: Force-Profiler cluster dialog problems with close button
    - Fixed: Force-Profiler profile load crash (Sliders and not save program settings)
    - Fixed: LFS plugin stopped on new track
    - Fixed: NSR1 plugin stopped on new track
    - Fixed: Sender crash if choose none plugin
    - Added: Dirt2 extradata plugin
    2.1.0.3
    - Fixed: false offline display after reconnect of chat system
    - Fixed: double logins with same name will kill other sender (now disconnects)
    - Fixed: Problem with the X Button of the plugin assistant solved
    - Fixed: Disconnect message box blocks gaming -> removed
    - Fixed: Profiler will load PNP detection wrong or enable it suddenly
    - Fixed: Profiler will load artificial breaks wrong (program setup)
    - Fixed: Profiler speech disable will sometimes return with defective registry
    - Fixed: Video plugin playback mode (fsm and fs2 files are no longer supported)
    - Fixed: Bug in rosterlist
    - Added: External roster box
    - Added: Video plugin vibration overlay
    - Added: False typed character in send message will now be displayed
    Changes.txt
    Bleco
  9. bvillersjr
    Ohio, USA
    438Coins
    That's correct. I keep saying 2.1.0.3 when I mean 2.1.0.13
    That said, of the two version that you can download, 2.0.8.9 (also referred to as 2.0.8.9b) is the best choice.
