USO COMMANDS FOR JRK12V HELP
Discussion in 'Force-Profiler Simulator Control' started by jimakosgr2002, Apr 22, 2011.
  1. bsft
  2. jimakosgr2002
    jimakosgr2002 Member
    PANELBEATER
    GREECE ATHENS
    273Coins
    I FOUND THAT THE MOST POWERFULL WIPERMOTORS HAVE THE GROUN UP ON THE METAL MY MOTORS ARE ISOLATED BUT NO TO MUCH STRONG NO WHEN TAKE COMMANDS FROM THE PROGRAMS TO GO BACK AND FORTH BUT WHEN i SIT DOWN TO THE BACKET THE MOTORS GO BACK FROM THE HEAVY FROM MY BACK WHEN PUSH START AND THE MOTORS GO TO THE MIDLE POINT OK BUT WHEN STOP THE BACKET GOES LEFT OR RIGHT OR BACK OR FORH thw other motors it was harder to push the frame with my hand and i try to put on the frame the pedals and wheel and move it all with my body on air but when l go left or right some time the motos didnt have power to move me maybe i need another one motor and jrk.I have here 10 motors when i open the motors from the back black some motors never working good like u say now i tri to conect the pots to the plastik gear in the motor i think that is beter and easer for me.U set the pots beter but i am so tired to think again and again what i must to do maybe in the future hahaha THE easer way must be with acuators but if i order something like tat and pay taxs for two than my wife she take me away from my house hahaha beter the motors i take somes from my work and test and i pay some about 20e the one
  3. eaorobbie
    20,488Coins
    same error as jim the earth on the motors is making contact somewhere inside or outside of motor which is making a deadshort to the jrk, resulting in mass heat and chip shutdown, becareful as this will send voltage down the usb cable and can blow ya motherboard. ISOLATE THE MOTOR CONTACTS
    Or ya got it wired up wrong.
