cant get Nacar 2003 + softth 3 screen to work with X-sim
Discussion in 'DIY Motion Simulator Projects' started by abs, Jun 7, 2011.
  1. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hello all, Ihave a 3 screen setup working with a software ( softth by kegetys ). Nascar 2003 works normally well but only without X-sim. when I try to use x-sim it jams at the loading data window.
    in my cae i bileve i have the latest patch and the telemetry directory is present with 3 files in it .
    i tried differet resolution also with no success.
    does any one have an idea of what i am overlooking ? help is meeded and appreciated
    thanks
  2. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    I figured it out for those in thes ame situation:
    start profiler and load profile
    start the sender and define what s needed (path of the game, nascar 2003 plugin , Ip adress) (do not hit play game and do not hit try to send data)
    start manyally Nascar 2003
    when the drive window appears , do not hit it yet
    hit in the sender the try to send data window
    now hit the window drive
    that is it
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Hi, try following:
    -leave the game path dialog empty
    -just enter an IP adress if you actually run a second computer/laptop for the profiler. Otherwise dont enter any IP adress.
    -check CPU load. I guess softTH consumes a lot of CPU performance. It may be too much in conjunction with the Profiler. Depending on the used profile and realtime settings as well.
    regards
