Shift 2 plugin
Discussion in 'Force-Sender & Plugins' started by Hobbs77, Jul 2, 2011.
  1. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Can anyone tell us why we don't have a working plugin for any of the NFS Shift series?
  2. bsft
    Possibly because no one gives a hoot about it!
    From what I read, the first NFS Shift set up was an injector plug in with info from the yoda program that made NO SENSE! Not all of us have c++ knowledge. Surely there MUST be a simple terminology way of helping the people on this forum.
    Heres what I found from another thread on this forum.
    Alright Folks, I have not plugged these values in to X-Sim but they should do just fine with Injector.
    Pitch: float: 0x00BDDDFC * 1000, limits (-200,200) add log. scaler in Profiler OK fine..
    Roll: I'll get back to you on this one. Let me take another look. Maybe needs pointer Huh?, surely you can specify a number for this!
    Lateral G's: float: 0x00BC8DC8 * 60000, limits (-70,70) Ok good....
    Speed: float: 0x00C14AF8 * 100 (0,lightspeed)Got that....
    Elevation: doesn't add much to this title Then why add it?
    You may have to fiddle with the multipliers a bit to get a clean run in Injector, upper limit is 10000 so do your best. Maybe Sirnoname can add another 0?
    Make sure to convert speed to G's in Injector.have Fun
    So maybe we need to do a course in c++ at cost to ourselves to run a video game? Surely someone has some decent values we can put it! I know , I read that a few people are running the injector with NFS Shift 1.
    Why doesn't there seem to be help? :sos:
  3. aikuo60
    aikuo60 New Member
    0Coins
    I agree with you, If someone could do the plugin.... I like this game! Or we should wait for the new X-Sim in 2012/13... :)
  4. bsft
    I would be happy to use the injector program, if someone would be kind enough to give a lamens terms to setting it up. That and some help getting yoda program to work, then I could do an injector file setup.
