cant find the parts to AVRC & DSMhb
Discussion in 'SimTools compatible interfaces' started by mickelmeck, Aug 27, 2011.
  1. mickelmeck
    mickelmeck New Member
    0Coins
    hello
    is it only me that have big problems to get the components for the
    AVR controller & DSMhb
    i have been looking on elfa and some internatinal electric component suppliers.
    any ideas to solove the problem :sos:
  2. pippo978
    pippo978 New Member
    Carini
    1,052Coins
    Hello Mickelmeck
    The components you can find them on http://www.reichelt.de, the site is in German but it is not hard to find. I found everything.
    Regards
  3. mickelmeck
    0Coins
    This is wierd i cant still find the capcitors 1000uF/16volt or the L 10uh (inductor coil choke in micro henry) maby you can help to get item parts number on all of the parts :)
    You should save may day then ;D
  4. pippo978
    pippo978 New Member
    Carini
    1,052Coins
    Hello
    This is the link to the capacitor 1000uF/16V http://www.reichelt.de/Elkos-radial...8AAAIAAEfIsq09cc1b586a19a508548b491b4e0e473c9 and here http://www.reichelt.de/Fest-Indukti...8AAAIAAEfIsq09cc1b586a19a508548b491b4e0e473c9 instead of the inductance 10uH These components are taken from Reichelt, but if you want you can buy them on other sites such as Mouser, RS, Farnell, Digikey. They are all well stocked and ship all over the world.
    But for what concerns the price is quite competitive and Reichelt.
    Regards
  5. mickelmeck
    0Coins
    So i can use this one
    L-HBCC 10µ 0,22 €
    Festinduktivität, axial, HBCC, Ferrit 10µ
    Liegende - Induktivität - Ferrit
    Festinduktivität mit niedrigem Innenwiderstand.
    Besonders für hohe Stromstärken geeignet.
    Axiale Bauform.
    • Toleranz: ±10 %
    • Ø 5,8 x 14,5mm
    L-HBCC 10µ
  6. mickelmeck
    0Coins
    now i have been out on http://www.reichelt.de
    i almost found all of the things i needed to the AVRC & DSMhb card's
    the only things i didn't get was the
    capacitor 100nF/100volt
    capacitor 1.2nF
    capacitor 22pF/100volt
    capacitor 18pF/100volt
    inductor, coil choke L 10uH
    some of the resistors like 47K Ohm 1/4w 1% i didn't neither find
    but i found 47k Ohm 0.5w (1/2w) 1%. is it okey to use them instead?
    it was the same for the zener diodes they were 1/4 w but i only found the 1/2w.
    i would be happy if i could get answer on this...
    it drives me realy crazy to not get the exact parts :?
  7. RaceRay
    Hamburg, Germany
    23,892Coins
