Pololu servo controller USB
Discussion in 'SimTools compatible interfaces' started by kenneth, Jul 11, 2011.
  1. kenneth
    kenneth New Member
    2Coins
    http://www.youtube.com/watch?v=cwkdfZaS13M
    http://www.youtube.com/watch?v=HdCxiaIo5hA
  2. kenneth
    kenneth New Member
    2Coins
    Here is some video of the sim hope you like it
  3. kenneth
    kenneth New Member
    2Coins
  4. kenneth
    kenneth New Member
    2Coins
    Wiring
    Each motor has a double pole isolator between the board and the motor in addition there is a fuse in both positive and negative lines to the motors.
    There is an emergency stop between the battery and the drives and a fuse circuit breaker.
    The 12volt 12 is the safest to program as the limits are in the drive unit.
    Danger the vin power output on the 12v12 is at the same voltage at your main power supply connecting this to the 5 volt line will blow it up.
    (I had the training course it cost the price of a new board.)
    X Sim I am using a mix on the side actuators 30% Pitch and 50% Turning(Not Bank)this as opposition left and right gives the heave motion.On the back I am only using Pitch
  5. BartS
    BartS Member
    417Coins
    Great stuff Kenneth the movement looks really smooth with transition in direction at slow speed. Thats a very original setup and still a little confusing to me but nevermind. Is all your math setup done in X-Sim?
    Be great if you got a rider on board and shot a video from rear facing monitor simulating game physics, both fast and slow to show off its potential, sorry my last request I'm very intreaged and I'm sure rest of the community is.
    Well done again Bart.
  6. kenneth
    kenneth New Member
    2Coins
    http://www.youtube.com/watch?v=Cj4kfFMKIoE
    Here is a better video with me attempting to drive it to the limits.
  7. BartS
    BartS Member
    417Coins
    Welldone again kenneth, not to discredit your work it is very good but dont you feel it moves a little slow, blast it with 24 volts is what wheelchair motors are made for, and your x-sim motion profile looks like it could do with some improvement and effect mixing if you arnt working on it already.
  8. RaceRay
    Hamburg, Germany
    23,884Coins
    Great setup and mechanical assembly!
    It´s even suitable to use it in the living room. Perfect solution for any flight simulation, i think.
    I agree to BartS: Would be great to see it with 24 V- but unfortunately not possible with the smc04.
    All the best to you
  9. kenneth
    kenneth New Member
    2Coins
    Hi all thanks for the comments. I designed it to go through a home door 800 mm wide . Regarding the speed you will be suprised how fast the reaction time is . It is to react like an aircraft or a helicopter and for that reason if it was any faster then you would brake the wings off. You do get a verry good runway rumble .If taken to the limit full pitch up and full bank and you need a safety belt to keep you in it . I found this out the hard way.I do plan to have the cockpit fully enclosed by doing this and removing the periferal vision the fealing of actualy flying will be grater. That's my next project.
  10. kenneth
    kenneth New Member
    2Coins
    Hi all been building and testing for several months now almost complete with a fully enclosed motion cockpit.Pix to follow.
  11. kenneth
    kenneth New Member
    2Coins
  12. kenneth
    kenneth New Member
    2Coins
  13. kenneth
    kenneth New Member
    2Coins
    Got the drawings here grate job thanks made this chair in 1.5 hours
  14. kenneth
    kenneth New Member
    2Coins
  15. kenneth
    kenneth New Member
    2Coins
  16. bsft
    yeah...looking good!
