proportional valve in x-sim.
Discussion in 'SimTools compatible interfaces' started by ch@rles, Sep 6, 2011.
  1. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    hello
    Someone has a profile example, how to configure a proportional valve in x-sim. (with a Velleman 110)
    thanks Charles :sos: :sos:
    sorry for my bad english
  2. eaorobbie
    20,481Coins
  3. bigtalltim
    bigtalltim New Member
    Belfast
    361Coins
    Hi Charles
    If you have a proportional valve already, let me know the spec/serial number and I'll have a look at a profile solution for you
    If not, hold on for a week or two - I am actually working on a K8055 based pnumatic rig myself right now ;)
    I have the components arriving at the end of the week for final prototype, though I am not looking to use a proportional valve... they're far too expensive (and if my rig works correctly, unnecessary!) My basic pneumatic solution is unlike any of the ones posted previously, is very simple and comparatively cheap, and should operate with variable speed... I'm afraid only testing will confirm this - I have nothing to compare it to!
    I will start a new thread with a full set of instructions when I have it built :thbup:
    Regards
    Tim
  4. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    Hi Tim and Eaorobbie
    thanks for your answer
    Tim
    I use proportional valve used car, but very curious about you new project
    I've found a solution to my problem.
    thanks Charles
  5. bigtalltim
    Belfast
    361Coins
    Good to hear you have your problem fixed! :thbup:
    Regards
    Tim
    PS. you wont have to be curious for too much longer - I have just finished building the electrical parts of the setup - just waiting on the cylanders and valves now...
