AMC problem - Help for winzzy
Discussion in 'SimTools compatible interfaces' started by bsft, Jan 12, 2012.
  1. bsft
    Hello , Winzzy is having issues connecting his AMC up to the x-sim software. I cannot help, as I am not familiar with the AMC setup.
    I have copied the information and photos he has sent me.
    Perhaps someone can look at it and direct message him
    Still can not. axis not output .....
    I like you to buy the motor. like your design.
    Your force feedback seat Movement is very real. Very powerful.
    I would buy the same motor . I also want to feel.
    but the G27 axis can not output .....
    I use AMC1.5. DSMhb1.2b. worm gear motor
    My g27 steering wheel throttle ..... axis movement. Motor no movement ...
    xsim 2.0.8.9 and xsim 2.0.1.3 axis can not output. Search not see any axis outputs.
    Datapacket with axisnformations: AB ~ 255 ~ ~ a01 ~ ~ a02 ~?
    IRFZ44N IRLZ44N work the same?
    I use IRFZ44N. How can I do? Please help me!
    connect Start.
    move the slider left and right.
    two motor motion ..
    but the G27-axis motion.
    two motor no motion.
    x-sim search no output axis.
    Can you give me x-sim set pictures and x-sim set video it?
    my email zzy2clm@163.com
      249.8 KB
      663
      258.5 KB
      646
      282.3 KB
      666
      225.2 KB
      645
  2. bsft
    Thanks for the help Sir, but do you have a direct link for this guy please?
  3. bsft
  4. winzzy
    winzzy New Member
    0Coins
    Dear bsft!!!Thank you very much for your help!!!
  5. winzzy
    winzzy New Member
    0Coins
    connect Start. move the slider left and right. motor motion .
    but the G27-axis motion. motor no motion. x-sim search no output axis.
    I use z-tek ZE533:Chip FTDI-FT232. Support serial.
    Support RS232. Support automatic handshake.
      6.7 KB
      2,891
  6. winzzy
    winzzy New Member
    0Coins
    Dear sirnoname!!!
    Thank you very much!!!
  7. winzzy
    winzzy New Member
    0Coins
    Thank ua6aak sharing! Download the game in the settings file ua6aak_RBR.rn2.
    COM5 port set printer support.
    run Force-Sender try send data.
    Force-Profiler load file ua6aak_RBR.rn2.
    Set COM5 port.
    Start ......
    Click Math setup calibration offset of this axis.
    two motor motion ...
    but the G27-axis motion....
    two motor no motion....
    Where the error?
    Can you give me your set picture or set video?
    Thanks!!! Please help me!
  8. Hardsteel73
    Hardsteel73 Hardsteel73
    Self employed
    bergschenhoek
    162Coins
    I had the same problem. I had the 24 crystal with 18 pf. Changed to 18 mhz and 22pf. Disconnect h bridge. Clean the back of yuor board with paintthinner. Because the slack of welding can cause a short circuit. Also look if no mistake is made with welding. Then star force sender with testplug in. In profiler make two axis and in uso do the com port and AB a01 etc
    Then it worked for me
  9. winzzy
    winzzy New Member
    0Coins
    Hello Hardsteel73!!!
    Have been a few days. Can not find the reason.
    How can I do?
    Can you give me More picture or video guidelines for it? Thank you!
