4DOF FIRMWARE
Discussion in 'New users start here - FAQ' started by fooons, Jan 18, 2012.
  1. fooons
    fooons New Member
    Técnico Sistemas Informáticos
    España
    272Coins
    Hello friends,
    I have built an AMC 1.5b controller and its H-bridge, all works ok but I want more and Thanos controller supports 4 motors but no implemented yet. I want to test it with this 4 motors but no firmware is available.
    Could someone give me an alternative?
  2. yobuddy
    51,260Coins
    Just build another set of what you built already!
    so you will have 2 AMC's and 2 H-Bridges.
    then you can do up to 4DOF.
    The main reason there was never a 4DOF Hex is it uses the LCD line - so no LCD anymore - and the 3rd and 4th axis would only be 8 bit rather that 10.
