How to deal with "Error opening comport COM4"?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jia, Jan 30, 2012.
  1. jia
    jia New Member
    0Coins
    hi all,
    I am a new user of X-Sim. I'd like to DIY a motion simulator with X-Sim and SCN5 cylinder.
    My SCN5 cylinder connects to PC via USB with RS-485 To USB converter.
    Now, when I click Try send data at X-Sim force-sender, X-Sim profiler will run Start, too. But when I click Disconnect at force-sender, there will appear a dialog box Error opening comport COM4 at profiler.
    How to deal with this problem?
    Thanks.
  2. yobuddy
    51,656Coins
    Can I get a picture of your interface settings in profiler.
  3. jia
    jia New Member
    0Coins
    hi, yobuddy
    Here is the screenshot of my interface settings.
    Thanks.
  4. yobuddy
    51,656Coins
    nothing there, how about a shot of the scn5 settings page one for each axis
  5. yobuddy
    51,656Coins
    what OS are you running?
  6. jia
    jia New Member
    0Coins
    hi, yobuddy
    Here is the screenshot of my SCN5 settings. Now I just have one SCN5 connected to PC.
    Thanks.
  7. jia
    jia New Member
    0Coins
    My OS is Win7.
  8. yobuddy
    51,656Coins
    Have you set profiler.exe to run as administrator?
    Id set force sender to run as admin also.
    Can i have one last picture of your Ports (Com & LPT)” in Device manager?
  9. jia
    jia New Member
    0Coins
    hi yobuddy,
    I didn't set these programs to run as administrator. I'll try it soon, thanks for this suggestion!!
    And here is the screenshot of my device manager.
    Thanks.
  10. jia
    jia New Member
    0Coins
    I tried set these programs to run as administrator, but the error message is still exist.
  11. yobuddy
    51,656Coins
    Did you set your adapter setting like this?
    Only other thing I think it could be is the adapter is not based on a FTDI chip.
  12. jia
    jia New Member
    0Coins
    Yes, I have the same settings as your screenshot.
    In fact, I can run these programs well, the message just appeared when force-sender disconnected(e.g. leave a game).
  13. yobuddy
    51,656Coins
    Well I'm glad it works!
    I would bet the problem lies in the prolific driver, but its just a guess! :?
  14. jia
    jia New Member
    0Coins
    Thank you very much, yobuddy.
  15. jia
    jia New Member
    0Coins
    hi sirnoname,
    I used the comport for SCN5 plugin and in the USO dialog.
    Here are the screenshots of the two pages.
    [img600px]http://www.mojoimage.com/free-image-hosting-09/507__scn5.png[/img600px]
    If I disable SCN5 plugin and disable the actuator, that error message box will not appear.
    Thanks.
  16. yobuddy
    51,656Coins
    Please click Remove Comport - it's in the second picture you posted, near the bottom right.
    That should clear the Select comport to edit in USO, you don't need that I believe.
    Then give the program a try, I bet it works.
  17. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    In my case, one few times I get error opening com port so I reset x-sim (other stuff folder >registry cleaner) and reset the AMC and everything comes back to normal.
    This is more often when massively changing/tweaking profiles...
    :highfive:
  18. jia
    jia New Member
    0Coins
    Yes!! The problem is solved.
    Thank you.
    Now I have a new problem. I followed http://www.x-simulator.de/forum/x-sim-2-0-video-tutorials-t1214.html to set force-sender and profiler, but my profiler can't receive effect values( input #21~#40). These values were always zero.
    Did I set some settings wrong?
    I run rFactor game and use rFactor plugin.
    Thank you.
