Buttkicker and X-Sim
Discussion in 'Motor actuators and drivers' started by rafael_design, Jan 31, 2012.
  1. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    I am thinking about buying a buttkicker to add to my sim rig but I dont know much about it.
    Can I install it fairly easy and use together with x-sim?
    My idea is to add vibration of engine and such fx to the experience ... Is it worth? Is it possible?
    Thanks!
    Rafael.
  2. yobuddy
    51,260Coins
    Sure you can add one!
    look here - it's all built in for you!
  3. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Correct me if I am wrong but I presume you would simply need to add an axis with the name of your detected device and then add the effect 57 ... ?
    I have no buttkicker ...
    Bleco
  4. yobuddy
    51,260Coins
    Sorry buddy, I don't have one either.
    Maybe someone with one could help you out more with specifics.
  5. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hi bleco , that s right , for volum and frequency
    that s what i did
    some may add speed effect instead . i did not try what s best. i had good result with rpm effect
  6. robert
    robert New Member
    holland/ amsterdam
    405Coins
    3DOF, Motion platform
    hi all,
    What if the profiler don't find any soundcard? that is mine problem.
    I have also the buttkicker and the plugin, and a use a laptop for the second soundcard.
    What i miss?
    Fox
