Winch Motors
Discussion in 'DIY Motion Simulator Projects' started by stowaway, Feb 14, 2012.
  1. stowaway
    stowaway New Member
    Gold Coast - Australia
    1Coins
  2. yobuddy
    51,524Coins
    I don't think you need to pay for the wireless stuff.
    And I would stay just under 30a and you will have more options for connection them to the pc
    I would use these probably :cheers:
  3. yobuddy
    51,524Coins
    I actually moded a winch motor a very long time ago that I still use for various projects today. :hi:
    Its pretty easy, just remove the cable wheel and cut the sides off of it.
    Insert a hole cut out out of HDPE ½” as a spacer and bolt it together.
    Then you put it back together with a belt and drill new holes for the base (see pic)
    You can even attach the pot right in the end on the winch motor if you get a little tricky. :thbup:
    Then you have to buy your wife a new cutting board if you drilled a hole out of it - lol :blush:
  4. yobuddy
    51,524Coins
    stowaway - I PM 'ed you buddy
  5. eaorobbie
    20,502Coins
  6. stowaway
    stowaway New Member
    1Coins
    I was actually just choosing the cheapest one I could find in Australia.. I didnt care about the Wireless factor.
    If I could get one quieter I would, but I dont really think there is any way i am going to be able to tell. so Ill probably just go for the super cheap auto one because its tried and tested.
    besides i asked the ebay guy fro a discount on 3, and he wouldnt offer it.
  7. eaorobbie
    20,502Coins
    yes a desktop test unit is recommended just to get it all right and sorted before building the whole unit. I ended up paying $150 for a pair, bargin considering im only using them for a frex 2dof but have the power and speed to move the whole unit. chair,wheel and pedals all combined.
    Tested to 200kg of dead weight (sand bags) in the seat for a 2hour run with ai driving in rfactor then for fun i sat on top of the bags for half an hour, about as long as i could hang on. So thats a 280kg test. Have ya built a model yet to test your theories.?
  8. stowaway
    stowaway New Member
    1Coins
  9. eaorobbie
    20,502Coins
    same model inside as the supercheap ones, good price.
    I just happen to be in the shop picking up some seat cover for the wife when i spotted the winches and thought maybe i could replace my useless wipers with thos mmmm, stuff it so i bought two and never looked back. Nearly forgot the wifes seat covers, oops.
  10. tahustvedt
    tahustvedt Member
    62Coins
    I removed the clutch plates from mine, and switched the clutch gear for the output gear, which fits the shaft directly, but needs a spacer to replace the thickness of the clutch plate.
