K8055 + Sabertooth + Wiper motors
Discussion in 'SimTools compatible interfaces' started by adbgg, Dec 19, 2010.
  1. delumerlino
    delumerlino New Member
    0Coins
    Do someone have tested it with Richard Burns Rally?
    Thanks a lot,
    Andrea
  2. DannyT
    DannyT Rider
    219Coins
    just one question. As the poti has a bad feedback to the K8055, I managed to connect the poti direct to the IC3 as mentioned often here in the forum. Unfortunely, after removing the IC1 the power supply to the DAC1/2 output fails. How can I manage to have power on the analoge outputs without the IC1??
    Highly appreciate any help :sos:
    Danny
  3. DannyT
    DannyT Rider
    219Coins
    Okay, to everyone who have the same problem: In order to keep the analog output alive after connecting the potis to the IC3 directly, you have to bent over (or remove) pin 1 + 7 of IC1 and push it in IC1 again..
  4. Aproxx
    Aproxx New Member
    0Coins
    Hi zusammen
    ich bin auch ein sim racing fan und arbeite mich gerade in die materie ein, weil mich die sache so begeistert hat und so ein ich will auch haben effekt auslöste.
    evtl werde ich mir so was, was auf diesem thread aufbaut, nachbauen.
    diese motorsteuerung, gibt es die auch in deutschland? oder eine alternative, die in deutschland hergestellt wird?
    achso, ich suche schon seit gestern nach ner deutschen faq. wo finde ich die denn? (also was mehr die hardware angeht.)
    Danke, und ich hoffe es ist ok, das ich mal in deutsch nachfrage ;)
    gruß
    Mario
  5. Menix
    Menix Member Gold Contributor
    104Coins
    Hi all
    I tried the same configuration
    but unfortunetaly i changed b+ and b- at my sabertooth 2x25 so i think i destroyed the mosfets because
    the motors spin only in 1 direction.
    no errors on the board.
    tryed with poti and k8055
    no chance to reverse direction only with change motorcables
    update
    there is only motor 2 who runs only 1 direction
    motor 1 works correctly.
    i have the sabertooth 2x25 V2
  6. supermodfan
    supermodfan 2DOF Wheelchair motors
    Electronics Field Service Technician
    Pulaski, NY USA
    296Coins
    2DOF, DC motor
    I have been following this post for some time and after building a test bed from Tim's dual relay, I decided to go with the Sabertooth, I am stuck at the yo-yo phase nd using 2 speeds just isn't enough to solve the problem. The motors still do a run away, but that will be cured with some limit switches. It has been a frustrating 8 hours but I am sure it will be an even longer night in New York trying to get this thing worked out...
  7. libory
    libory New Member Gold Contributor
    - 13Coins
    Hi, I don't know if this is going to help about the yo-yo problem but it worked for me and now I don't have to use 2 speeds as never worked for me. Try to setup your motors with dinamic speed with this settings:
    The speed of the motors you want to go is set up with the dynamic slider. The more percent the faster your motors will go. 0% your motors won't move, to decide the direction of the motor just move to the left or to the right. Left it might go in positive direction or up and right it might go to negative direction or down it depends how you have setup your motor cables. It is very important to keep the slider on the bottom at %50 or you will get that annoying yoyo problem. I hope this helps.
  8. supermodfan
    Pulaski, NY USA
    296Coins
    2DOF, DC motor
    WOW Thank you so much libary, I had tried the Dynamic speed settings with all sorts of different numbers not knowing exactly where to position the sliders and I had runaways and and the same herky jerky motions, but with it set just like you have posted the sim works PERFECTLY! I will attempt to get some video of it today, and then comes the fun of the profile hahaha. Again, thank you so much!
  9. adbgg
    adbgg Member
    132Coins
    Hi libory / supermodfan,
    Do you mean that the dynamic speed really works ? I'm not able to try since I have put everything in a box (all my materials, cards, motors, ...) 6 months ago.
    I had no time the last 6 months to work on that project, even if I have everything to build the frame. But not enough time (business, family) :)
    If the configuration of dynamic speed you give in the above message really works, I will put a link in the first page of this post.
    Thanks you libory / supermodfan,
    Thanks you to all people how contributes and are involved in this post, because I'm not able to continue on this project anymore at the moment.
    Thanks to Stephane61.
    Happy to see that this combination (K8055 + Sabertooth) encourage some people trying to build their own frame.
    Bye
  10. stephane-d.61
    stephane-d.61 New Member
    341Coins
    Thanks to you adbgg ! You gave the idea and I did just that follow in your footsteps.
  11. libory
    - 13Coins
    Hi adbgg.... yes it works.. and thanks to you I saw all your progress and I did mine simulator too :) With dynamic speed works very smooth... you should assemble again yours and give it a try ;)
  12. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Hello to all
    I apologize for any errors in translation made by google ... unfortunately I do not speak English.
    Adbgg Congratulations :cheers: for your project and guide you did! I've done venine want you to build a simulator, and much that we thought but I never started ... now that I found this wonderful forum and your help I finally put to work. I state that the beginner but I am sure that with your help we can build it.
    First problem, and the purchase of K8055 velleiman since there are various models I would not go wrong buying ...
    I found this:
    K8055N
    Uploaded with ImageShack.us
    And this: VM110N
    Which one is good? the last N I convence .....
    And this The Sabertooth 2X12 and 'the ideal choice for small robot propulsion differential control 2 motors 12A.
    Thanks in advance ;D
  13. stephane-d.61
    341Coins
    They are the same card, except that the K8055 is supplied loose while for the VM110, all components are already welded. For Sabertooth, the 2x12A is a good choice
    ( je ne sais pas si tu es français mais si c'est le cas, voilà la traduction: Ce sont les mêmes cartes à la différence que la K8055 n'est pas livrée montée alors que pour la VM110, les composants sont déjà soudés. pour la sabertooth, la 2X12A est un bon choix.)
  14. -kevin-
    128Coins
    Hello and thanks for the answer! (I'm Italian)
    Ok then proceed to the purchase of VM110N and Sabertooth 2X12A :thbup:
    The only question that I and the (N) Final ..... What does it mean? because they are seeing on the forums and on youtube else is not the N :?
  15. stephane-d.61
    341Coins
    I feel as Version N is a simplified version. No LED etc ... but I'm not sure
  16. JimmyT
    JimmyT New Member
    477Coins
    In the tutorial on the front page of this thread It talks about force sender. I have x-sim ver 3 free version and extractor and can't find the force sender so can't use test tablet to test the motor without using a pre defined profile. I have not set up the hardware yet but tried to find all the software to see how this works before I spend my money. Can someone tell me how to open Force Sender
    Thank you in advance.
    By the way, I have found this thread most helpful and will most likely get started on a motion sim using this setup in the next few weeks. Thank you to all the contributors.
  17. stephane-d.61
    341Coins
    in version 3, Force Sender is now named Extractor. I can not explain its setting because I just installed it and now I can not save my profiles. I'm not sure but I understand the need to buy a license to save profiles.
  18. bsft
    You can save profiles, do it exactly the same way as ver2, go to profiles - save - ....... easy. You do not need a licence to save profiles
  19. -kevin-
    128Coins
    Ok then, expect that someone gives me the certainty that the (N) does not imply the final function of what I do ;D
    thanks
  20. stephane-d.61
    341Coins
    I searched in the site of Velleman. The K8055N version is a new version of the K8055. But I advise you to take the VM110N because it is the already built version. Otherwise you will have to weld components.
