Tronic's AMC motor motion-controller with pwm/servo output
Discussion in 'SimTools compatible interfaces' started by tronicgr, Aug 30, 2007.
  1. tronicgr
    tronicgr
    Hi Rene, Maurice,
    The project is open and can be accessed by all x-sim.de users. That means that you have to be registered and already logged in x-sim.de to be able to open the links. Sorry if its private/closed for the rest of the world but its a x-sim3 project and we need more people there.
    I maybe open it for non-xsim3 users if there is enough interest.
  2. dutch_anykey
    dutch_anykey New Member
    Intelligent networks gsm prepaid services and such
    305Coins
    Hi Thanos,
    thanks.
    It works, I created an account there as well. I was under the assumption that it al was under the same website ;-)
    br
    Maurice
  3. tronicgr
    tronicgr
  4. value1
    15,032Coins
    I like your oscilloscope! Quite smart! :)
  5. tronicgr
    tronicgr
    Thanks, its a cheapy DSO201... got it some years ago.
  6. faelvasco
    faelvasco New Member
    Londrina - BR
    0Coins
    Thanos let me ask you.
    Why did you removed the firmware 1.5 of amc?
    you will put a firmware that supports 1.6 and 1.6 AMC?
  7. tronicgr
    tronicgr
    Because its outdated now, and I would like that board to be retired...
    An alternative you can try is this one here: revolution-firmware-and-software-for-amc1-5-t3912.html (but its only for ATmega8535)
  8. faelvasco
    Londrina - BR
    0Coins
    but will you take off everythink about 1.5?? because i start to build this board before you lunch 1.6... And of course i will need information on this theat..
  9. tronicgr
    tronicgr
    Nothing will be taken off this thread. Its needed as reference.
    As I told you, there is an alternative firmware you can use but if you insist I'll PM you the firmware for AMC1.5
  10. faelvasco
    Londrina - BR
    0Coins
    Thanks thanos but there is no need to PM the fw of 1.5. I already have it, get it before you take off the link.
    And would like to build the board 1.6 but i have all the components and start to soldering my amc 1.5. Maybe if i can´t do the amc 1.5 gonna try 1.6.
    Thanks anyway
  11. tronicgr
    tronicgr
    AMC1.6 uses almost the same components as AMC1.5 and even less and the main difference is that it uses exclusively ATmega644 and the sparkfun FTDI USB breakout board for both power and serial communication.
  12. dualin
    dualin Member
    Cáceres - Spain
    - 41Coins
    Hi, I've the AMC 1.5 (with the alternative firmware) and the DSMhb. The dual bridge doesn't works (a few parts have burn) then I need a new one. Someone knows if I can use this one with my AMC 1.5?
    http://www.ebay.com/itm/High-Current-Du ... 6rk%3D1%26
    Thanks in advance and best regards
    Dualin
  13. faelvasco
    Londrina - BR
    0Coins
    I started to soldering my board AMC 1.5 and had a little problem in soldering actually were 2.
    One. when i soldering the point i did a little error. I remove the tin with the sucker and I took the trail. Than i canot make any soldering more.
    2nd. after welding energy input it got a little upwards and taken off the trail a bit welded in the board, redid the solder to track still on the board.
    but I think everything is routed .. I do not know if it will make much difference without leaving the component soldering since the track was not going anywhere.
    following images
  14. xtech007
    xtech007 Member
    29Coins
    Wow ! man I was gone!
    Decided to dust out my old AVR v1.5 and give it a whirl!
    Works! original v1 22hz crystal firmware by Tronic. LCD runs, displays 128-128-513-523.
    when pot is moved to either direction the number changes, when I connect second pot the board freaks out.
    Can't say same for the H-Bridge V1.2b.
    at first all all output LED's worked according to what I moved the pot, suddenly motor 2 green light quit, just the red would light up. Cool, replaced IRF4905L had extra 4, worked for a sec.
    Now got new Symptoms:
    motor 1 produces 11.79 volts at full bright RED LED (pot full turn on one direction), and Only -2.54 at full GREEN LED (pot full turn in opposite direction)
    Motor 2 Produces 11.79 volts at full bright RED LED, and when I move pot anywhere past mid position towards opposite turn stays at .28 volts.
    No motor are Attached just multimeter!
    And at last Buddy just quit, No LED's reacts nor any voltage is read on the motor out.
    I can read 12 volts on the motors supply.
    So, I'm out of Extra parts!!! :sos:
    But I do Have an MD03 here is the link:
    http://www.robot-electronics.co.uk/htm/md03tech.htm
    Question:
    Can I use Tronic's Avr to control the MD03?
    Got 2 laying around, but can't get my head around how to connect them to the AVR.
    I see pololu h-bridge are being used, will be ordering soon.
    Thanks in advance!
  15. kbssa
    kbssa New Member
    Brazil
    0Coins
  16. TheXRacer
    TheXRacer Cougarsimulations SimAxe Beta Tester
    349Coins
    2DOF, 3DOF, DC motor, Arduino, SimforceGT
    Hello all,
    my AMC 1.6 works for 2 Days , now it maks some Problems :
    1) with and without Pots the Position from the Xand Y-Achses goest to the max ?
    With every Firmware ;(
    Witch Problem is this i can flash the AMC 1.6 and all Axes goes to max ; what make it wrong ?
    Please help me, i found any answer :sos: :eek:
    Thanks for each help!!!
    ps: sorry for the bad qualy
    gears
    Christian
  17. TheXRacer
    349Coins
    Oh, my AMC 1.6 Works
    My Atmega 644 was not correct in his socket :lol:
    gears
    Chris
  18. TheXRacer
    349Coins
    Hello all i´,
    I need our help !
    Every time I connect the AMC 1.6 with X-Sim3 plus a game (R-Factor 1) Create the controller resets and a new function of the 2DOF system is impossible!
    Does anyone know of what could be the problem, if so please contact my.
    Here is a little video of my problem
    Youtube Link : http://www.youtube.com/watch?v=cxsVEJgK ... e=youtu.be
    greetings
    Christian
  19. TheXRacer
    349Coins
    Here my Setting , can anyone check this I use Firmware 1.1d :
  20. TheXRacer
    349Coins
    Hey all ,
    i solved the Problem with a big help from Bruno ( X-Sim.de) :cheers: :thbup: :thbup: :thbup: :thbup: :thbup: :cheers:
    I chanched the Crystal ( Quarz ) from 22.1184 to 18.432MHz an all work well/ fine :yippiee:
    Thank all peopels were supportet my :highfive:
    best regards
    Christian
