my firts project
Discussion in 'DIY Motion Simulator Projects' started by christianr3, Mar 2, 2012.
  1. nicko_esx
    nicko_esx Member
    argentina
    696Coins
    hola christian.
    una duda. alguna vez usaste xsim????
    tengo algunos tutoriales... te pueden servir si es que no usaste nunca.
    yo nunca use esas tarjetas pololu. uso arduino... estoy empezando recién en este mundo electronico :D
  2. bsft
    Please register with www.x-sim.de as i am going to post instructional videos. The set up for x-sim 3 and USO commands is the same as x-sim 2, just other features are different.
  3. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    hola nicko, yo nunca he utilizado x-sim, acabo de terminar mi primer simulador pero no se como se configura x-sim, tengo un tutorial que me distes pero la verdad no lo entendi. quisiera saber si tienes un tutorial paso a paso para configurar x-sim, gracias amigo
  4. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    I signed on that page, but I understand that there are q pay 30 euros to use the software without internet connection and I still need money to buy the seat and I can not afford x-SIM3
    Please register with http://www.x-sim.de as i am going to post instructional videos. The set up for x-sim 3 and USO commands is the same as x-sim 2, just other features are different.[/quote]
  5. tronicgr
    tronicgr
    Well, there is a rumor around that the best beta helper will be granted a free offline supporter key at the end of each beta test period!!
    Hurry up... ;-)))
  6. bsft
    [/quote]
    Check your personal email.....
  7. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    hello :hi: , here I will put photos of the progress of the configuration :hacker: , I am following the video put on youtube david (good video tutorial :clap: ), I wonder if I'm right, thanks!
  8. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    david (bsft) es un amigo de australia que me ayuda mucho en mi proyecto, el conoce mucho de simuladores, pero el usa tarjetas pololu igual que yo, pero creo que no puede orientar mucho en cuanto a la construccion se refiere :clap:
  9. nicko_esx
    nicko_esx Member
    argentina
    696Coins
    christian. en estas dos ultimas fotos falta que agregues las fuerzas para cada motor.
    hace una cosa.
    bajate cualquier perfil de cualquier juego. ejemplo el rfactor. y fijate lo que te digo. tienes que agruegar las lateral force. aceletation pich ... etc... para un motor y luego para el otro. si no me equivoco algunas variables tienes que darle a la pestaña invert. ejemplo lateral force asi se mueven en direcion opuesta cada motor lateral y genera la inclinacion.
    . luego con respecto a la imagen del USO.
    no se como sera que recibe la info esas plaquetas. ese es el gran desafio. pero por lo que veo. te falta agregar en el datapacket ambos motores. porque vos pusiste para el motor uno y otra para el motor 2. es decir en el datapacker van ambos ~a01~a02~ el tema es ver como enviarlo.
    otra cosa. con respecto a la configuracion de 8 bits. pero no se si recibira en binarios :S... proba cambiarle a decimales.... hay que ir probando jeje
  10. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    thanks for the info :thbup: , I think you are the creator of some cards, congratulations on your work, I see that many people use your system but I do not know anything about programming, congratulations on your work :yes:
  11. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
  12. bsft
    Yes, well done! Now to add some forces and fine numbers for them from a game!
  13. nicko_esx
    nicko_esx Member
    argentina
    696Coins
    bien christian.... bien....
    solo te falta agregar las fuerzas. lee el tuto o lo mp que te mande...
    ya tienes comunicacion entre xsim y las placas. es un gran paso.
    pero si pones un juego las placas no van a hacer nada si el xsim no tiene configurado que fuerzas enviar....
    no te olvides de dejar configurado el juego tambien
    recorda lo que te dije del rfactor
    el gtr2 tambien es de facil configuracion. creo que un archivo hay que modificar.
    dale dale metele pata :D
  14. astro
    astro New Member
    Argentina
    31Coins
    Hola christianr3!
    Gracias por el video, está muy bueno tu sim. :clap:
    ¿Qué motores usas?
    Yo también estoy probando con Arduino.
    ¿Podes compartir el código?
    ¿Por qué tenés COM10 y COM11? ¿Estas usando 2 Arduinos? :?
    Thanks for the video, your Sim is very good. :clap:
    What engines do you use?
    I am also experimenting with Arduino.
    Can you share the code?
    Why COM10 and COM11? Are you using 2 Arduinos? :?
  15. nicko_esx
    nicko_esx Member
    argentina
    696Coins
    astro. el no usa arduino. usa las placas pololu. son dos una por cada motor.
  16. astro
    astro New Member
    Argentina
    31Coins
    Ahhh perdón, me perdí leyendo tantos post y me confundí.
    ¡Muy buenos motores! :clap:
    Oh sorry, I'm lost reading so many post and I got confused.
    Very good engines! : clap:
  17. nicko_esx
    nicko_esx Member
    argentina
    696Coins
    los motores me dijo que son de carritos de golf. estan buenisimos. ya estoy buscando en ML para preguntar el precio jeje :D esta muy bueno el diseño del simu tambien. muy practico.
  18. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    hola :hi: , gracias por los comentarios, mi simulador es pequeño por que no tengo mucho espacio, mi diseño esta basado en un simulador hecho en europa que se llama atomic a2 , y me parece un buen diseño, es practico, y hecho para espacios pequeños, aqui en el foro hay personas que tienen simuladores 1000 veces mejor que el estoy construyendo, pero para mi el espacio es fundamental, quiero decirles que continuo haciendo pruebas , pero no entiendo por que los motores no se mueven con el test de force sender, es normal que no se mueva :dntknw: ??, o es que sucede un problema con la configuracion??, me podrian ayudar con el problema
    traduccion
    hi :hi: , thanks for the comments, my simulator is small because I have little space, my design is based on a simulator made ​​in europe is called atomic a2, and I think good design is practical, and made for small spaces here in the forum some people have simulators 1000 times better than I am building, but my space is essential, I say that I continue to do tests, but do not understand that the motors do not move with force test sender is normal not to move :dntknw: ??, or is that a problem occurs with the configuration? I could help with the problem
  19. bsft
    Remember in profiler, you need to add a force in the math section.
    Use the output1:1 and add a slider to the force section , one for each axis.
    then once that is done, click try to send data on sender and start on profiler.
    Then slide the slider you have set the force for.
    I am currently uploading a video for finding motion.
    I will email you a link later.
  20. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    thanks david! :thbup: , I'm trying to change the force, but can not find where changes, I will continue investigating :badpc:
