Profiler-output speeds
Discussion in 'Force-Profiler Simulator Control' started by CW, Aug 9, 2007.
  1. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Hi all, I wonder if anyone can explain how the output slow normal fast works in the profiler?
    I can make my sim actuators change speeds by using different bits on the output (through relays and varying resistance)
    The problem is how does the software send a signal to slow normal or fast.
    Even with my babelfish translation program I struggle to read German, any help appreciated.
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    In your case, for every movement direction and speed you'll have to assign only one action (unlike pneumatic pulscontrol).
    The Profiler 1.X does not send signals for slow and fast, but 8 I/0 signals.
    In your case, you could try to manage it this way.
    Slow:
    Motor 1
    - bit 1 = forward
    - bit 2 = backwards
    Motor 2
    -bit 3 = forward
    -bit 4 = backwards
    Normal:
    Motor 1
    - bit 5 = forward
    - bit 6 = backwards
    Motor 2
    - bit 7 = forward
    - bit 8 = backwards
    Fast:
    Motor 1
    - bit 1 + bit 5 = forward
    - bit 2 + bit 6 = backwards
    Motor 2
    - bit 3 + bit 7 = forward
    - bit 4 + bit 8 = backwards
    ego
  3. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Thanks ego,
    I have already set up my output like that, the problem is getting profiler to output the different bits, in other words if i turn slowly the sim will turn bit one on and if I turn normal bit 5 turns on, this doesnt seem to be happening.
  4. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    calibration toolbox.
    Thanks, had a play with the calibration toolbox and it appears to do what I need. speed should not be an issue, for this simas far as actuators are concerned I have plenty of speed and power.
