Tutorial DIY Polyester Cockpit
Discussion in 'DIY peripherals' started by pitstopp, May 22, 2013.
  1. pitstopp
    pitstopp Active Member
    Dortmund
    634Coins
    3DOF, SCN5, SimforceGT
    Here is a short Tutorial how to make a Cockpit (or any other Case, etc.) from Polyster fiber.
    First Step: We need a mold, here is shown how easy you can make a cheap lost mold.
    I took a block of Styropor an shaped out the form with a knife and a grater.
    The Surface should be smooth and symmetric.
    The Form of my Cockpit is a litlle bit to complex for a mold in one piece, so I had to split it.
    For a bigger form you can glue the Styropor togther with a special glue.
    Then you must cover the complete mold with wallpaper glue and newspaper.
    Cause the Polyester resin would dissolve the Styropor. If you use Styrodur you can skip this step . Styrodur is resistant, but much more expansive.
    Everything ready to laminate !
    Cut out some Fiberpeaces that fit the place you want to start.
    Saturate the mold and the Fiber and put the fiber in place.
    Then push out the air under the fiber with a short Hair Paintbrush.
    That is important for stability reasons.
    WARNING: Don`t mix more than 500g of Resin, the resin will get stuck in less than 20 min!
    Work in Progress!
    First Part is finished!
    Here the Parts for the Midle of the Cockpit
    Every thing fits together
    Cut off the outer edges and make everything ready for glueing together.
    Have an eye if it is symetric!
    you need special fiber-reinforced glue!
    First test, not too bad!
    You have to fill the surface for a perfect paint
    This is only a short Tutorial, there ar a lot of Videos on YT. Key words: Doorbords, RC Plane Body
    For a first attempt this is possible to difficult.
    Try to make a Button Box, You can use your Girlfriends Tupperbox as a positiv mold!
    It is really easy to get good results and it is not more expansive than Metal or wood .
    Find out a company those who make car Tuning Body work or RC Planes.
    Speak to your local Car Painter for hints!
    If you have found a company they will supply you with every thing you need !
    Thanks for your attention
    Kai
    • Like Like x 14
  2. value1
    14,270Coins
    :clap: Beautiful! Nicely made! :clap:
  3. eaorobbie
    20,506Coins
    Very nice always wanted something a long those lines, really looks great and all, done a button box before but never thought of using foam to create the mold, love the idea of newspaper to cover mmmm feel a mod coming on. Bugger
    Thanks for the information very informative.
  4. pitstopp
    Dortmund
    634Coins
    Here some Pics of my first Cockpit.
    These is really easy to make, costs arround 50€ and takes 3-4 hours .
    Mold is an laundry Box (negativ).
    only put some molding wax in, as Formula 5, coating with gelcoat and 2-3 layer of poyester Fiber.
    The Frontpanel is made on a glasspanel to get an perfect flat surface.
    cut it out, glue it together, abrade the edges an give it a paint with the spray can.
    If you want a bigger Project , check this out
    diy-polyester-roof-t3473.html?hilit=polyester%20roof
    Best Regards
    Kai
  5. eaorobbie
    20,506Coins
    I like the idea, a nice way to really give that professional touch.
    My whole sim is 2 PVC seat Mover and you giving me ideas....
    Feel the need to mod ......
    Cheers
  6. bsft
    nice job
  7. ferslash
    ferslash Active Member
    4,798Coins
    nice!
    how did you painted the orange one? profesional air compressor? like a car?
  8. RaceRay
    Hamburg, Germany
    23,892Coins
    Wow awesome job. I am also interested in your paintjob. Looks very professional. Did you paint it at a paintshop?
  9. pitstopp
    Dortmund
    634Coins
    Hi
    I used a proffesional Spray Gun and a Compressor for the orange car paint.
    For the Black Stripes i used a Spraycan.
  10. mario318i
    mario318i New Member
    Wieselburg/Austria
    88Coins
  11. Historiker
    9,205Coins
    Wow, impressive!
  12. RacingMat
    21,088Coins
    Very good tutorial, pitstopp ! Thks
    Are fiber glass rolls (used for being glued and coated on walls) suitable for that ?
  13. pitstopp
    Dortmund
    634Coins
    Hallo
    no Fiberglass for walls is a totally diffrent product. I think it is only called Fiber Glass and has nothing to do with Fiber glass for Molds and modelling Parts.
  14. RacingMat
    21,088Coins
  15. pitstopp
    Dortmund
    634Coins
    Hi Mat,
    i think this offer is OK. Shipping costs are a little bit expansive, mhhh.
    I hope you keep us informed about the progress of your work :)
    Regards
    Kai
  16. eaorobbie
    20,506Coins
    Shipping cost is properly due to the transport of hazardous goods (resin).
  17. ericRacer
    Pilot
    Canada, Quebec
    922Coins
    Wow, impressive ! :thumbs thank you for sharing your work :cheers
  18. Albertus
    Albertus New Member
    Manager
    Standerton Mpumalanga South Africa
    131Coins
    I was wondering how they make fiberglass dashes! thanx man! Learned allot!
  19. Nath Older
    Nath Older Member
    Laboratory Supervisor
    United Kingdom
    271Coins
    This looks awsome. well done.
  20. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    thats is the coolest sh%t Ive seen in a while. I must steal this now!
