Full motion Home Flight Simulator
Discussion in 'DIY Motion Simulator Projects' started by schillermetall, Aug 5, 2013.
  1. schillermetall
    schillermetall New Member
    Metallbaumeister
    Berlin
    9Coins
    Hallo Gemeinde,
    ich wollte mich hier mal mit meinem Projekt vorstellen.
    Aufgabenstellung war, eine Motion-Plattform zu bauen, welche in Räumen bis 2,40m Raumhöhe zu betreiben und trotzdem 20° Neigungen in unter 1,5sek. schafft.
    Außerdem sollte sie große Lasten über 300Kg stemmen können, da mein Homecockpit aus einer Stahlrohrkonstruktion geschweißt ist und für 2 Personen vorgesehen ist.
    Das Ergebniss:
    Viele Grüße aus Berlin,
    Roland
  2. value1
    15,082Coins
    That's great :thumbs There's a lot I like about your simulator, e.g. all those screens!
    The solution with the lifting jacks is very clever, indeed.
    In your video you share a lot of technical details verbally. Would you be able to share some details also here in the forum?
    Very impressive! :thumbs
  3. schillermetall
    Metallbaumeister
    Berlin
    9Coins
    The idea really comes from a jack. When I went one day by my garage, I saw this jack. There I found out the idea.
    With pleasure I transmit technical details.
    There is one more video with youtube. There one sees the drive in detail.
  4. RaceRay
    Hamburg, Germany
    23,877Coins
    Absolut beeindruckend!!! Tolles Video, und endlich entspricht die Video-Aufnahmequalität auch mal dem Produkt, das gezeigt wird:)
  5. eaorobbie
    20,488Coins
    Top idea, think it was bsft who showed me some earlier pics of the build , well blow me over that is pretty damn cool.
    More detail please.
    i.e. any design info on remake of the jack ?
    What's the size (voltage, amps) you are using ?
    Thanks well done, love it.
  6. schillermetall
    Metallbaumeister
    Berlin
    9Coins
    Thanks for your complements. So far I have no drawings ready showing exactly the design. If there is enough feed back may be I will produce the jacks on request.
    The platform is driven with 24 V, and max 60A with a sabertooth controller. Maximum currents of about 100 A are coming up when the dirvers are turning into the opposite direction when moving downwards.
    Best regards
    Roland
  7. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,320Coins
    Fantastic simulator! I love how you it can seat two people - very nice. :clap:
  8. Historiker
    9,208Coins
    I am in awe, well done!
    I too would like more information on your lift mechanism. How did you fabricate the lifts?
  9. eaorobbie
    20,488Coins
    Thanks Ronald, thought you they were 24v units but had to ask, Im in the design stages of a 301 replica and think 24v is going to my option for lifting the main frame.
    When you get time , I feel the community in whole would love to see a design of the jack , even a rough theory of what you have done, innovative indeed.
    Right out of the square well done.
  10. eaorobbie
    20,488Coins
    How are you driving the sabertooths , Ard or K8055, been working on supporting the new driver from dimension engineering, Kangaroo. As the K8055 is not support in the software and the Kangaroo looks way better apart from 1/3 of the cost and yes it can be setup with USB.
  11. aarondc
    aarondc Member
    Melbourne, Australia
    193Coins
    Great simulator, well done.
    Any idea how heavy your entire rig is? Looks very solid!
  12. schillermetall
    Metallbaumeister
    Berlin
    9Coins
    Thanks to all of you for your interest. I will try to answer your question:
    The net weight of the platform is something around 500 kg.
    Unfortunately I am not a PC programmer thats the reason why I - unfortunately - cannot answer everything in detail.
    The sabertooth controler (2x 60 A) is drivern by the software of Ian Hopper.
    The wiring is exactly as per his drawing ( http://bffsimulation.com/sabertooth.php ). He did a fabulous job to get this thing running.
    Concerning more details I have to refer to my youtube videos showing the mechanical parts and drivers more detailed. Hope, that will help you.
    Best wishes
    Roland.
  13. bsft
    Great job dude!
    :hi:
  14. schillermetall
    Metallbaumeister
    Berlin
    9Coins
    In the drawing one can well recognise, how high and deeply the jack goes. In the comparison a hydraulic cylinder (or linear engine). Schere Höhenberechnung.jpg
  15. RaceRay
    Hamburg, Germany
    23,877Coins
    Beautiful!:) That´s an amazing comparison.
  16. RacingMat
    21,060Coins
    yes, this is a compact actuator !
    but the drawback is that speed is not linear.
    Turning the axle in low position, moves up quickly. But as time goes, the speed reduces...
    So the electronic has to compensate this.
    The advantage is a nice and smooth movement ! It is well done !
    Did you machine all the pieces or is it an electric jack you bought and modded ?
  17. RaceRay
    Hamburg, Germany
    23,877Coins
    Where did you get that formula Mat?
    Interesting thought! I am curious if chillermetall considered and compensated it.
    As far as i know he planed and construct the complete actuator by himself
  18. schillermetall
    Metallbaumeister
    Berlin
    9Coins
    All mechanical parts are from my production.
    First, I've experimented, such as speed and power are:
    Then I drew a design:
    At the end, a prototype was built:
    So Easy!
  19. RacingMat
    21,060Coins
    1 motor turn will shorten the horizontal screw by 1 cm (<>L in my sketch)
    - in low position, the arm will raise very much to compensate this 1 cm minus length of the screw
    - once raised, the arm will raise few to compensate :
    Considering this, I calculated it like this : jack speed.JPG
    Could you tell me if you used ball screw or simple screw with a nut ? I can't see
  20. schillermetall
    Metallbaumeister
    Berlin
    9Coins
    I use ball screw.
    Simple crew brake too heavily dignity.
