motor driver error pololu jrk 12v12
Discussion in 'DIY Motion Simulator Projects' started by christianr3, Aug 12, 2013.
  1. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    :hi: hello friends long time without going through here, actually I was a bit removed from the site because I have had to make many modifications to my simulator, I can say that is more advanced in its construction, and it works!, although I had many problems with a error that was causing me a big problem when using my cards pololu, this error is motor driver error, after much asking pololu people would tell me I could be that the card was being overloaded and it gave me that error , and talk to my friend david and I advise several tests :cheers: , in the end I have got the solution ... to change the uSB cable from the card q will pololu jrk12v-12 the error disappeared, not if by chance, I will continue doing test to see if the error becomes much! ... hope it does not happen again! anyway I hope this information helps someone who puedad have the same problem!
    ahhhh by the way, if anyone of you can help me set up the game formula1 2012 to work with my simulator I will thank, I could make it work with rfactor f1 2012 but codemaster not like the process!. .. thanks! :happy:
  2. value1
    15,026Coins
    Hi christianr3
    I also had issues with JRK connection loss and having to restart. I'm really cautious when comparing software but I have to say that since I am using SimTools connection loss never happened again (and my simulator is fairly heavy).
    Regarding F1 2012 it depends on the software you're using. Again, SimTools is fully compatible with F1 2012 without causing the famous crash at the end of a round.
    Kind regards,
    Thomas
  3. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    thanks for responding!, I use xsim 2.0, I have not used the version 3, say it is better than I use, but I like this, I know the sim tools, but you say that since you use sim tools and have not had problem with the card more jrk 12v-12?? ... as used?, ... also want to ask you if you use fromula 1 2012 ... can you help me install it? :D
  4. bsft
    Well done for finding the problem and fixing it on the JRKS.
    Simtools is awesome and there are NO dropouts in jrks. Fantastic.
    Motion is more refined. The guys have done a brilliant job.
  5. eaorobbie
    20,481Coins
    im using f12012 with sim tools about to test Sim Tools v3 on F1 2012. Time to join in beta test mate, and toss xsim out for good. Apply in related posted mate.
  6. eaorobbie
    20,481Coins
    Confirmed working in Sim Tools V3 with all forces, no game drop out in a 1hr session.
    Convert and join in the fun mate.
  7. value1
    15,026Coins
    Yes, I had am using the JRKs 12V12 and have no connection loss problems anymore since SimTools.
    Yes, for sure.
    First of all apply for SimTools Betatester, install SimTools, install/patch the F1 2012 plugin, have fun. It is really so easy!
    As eaorobbiel just kindly confirmed, F1 2012 runs smoothly with SimTools.
  8. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    :uups: wow! ... I spent so much time concentrating on my simulator build I had not realized that there was a new software to control the simulator! ... where I can download the simtools?? ... I'm a little confused :? .... is used alongside simtools xsim software? or software that is used alone?? ... where I can get information?? .... Here I show you some pictures of the progress of my simulator, paint it blue to look like the formula 1 redbull, and pedals put them in an elevated position to simulate driving a f1, I would like your opinions to see if I on track in the design! :highfive:
  9. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    value between to investigate some of the new software but in the other post says it is only for a selected group of people with knowledge, I honestly I have no knowledge to develop software, I think I will not be selected to use simtools, hopefully one day be free to use!, Greetings! :hi:
  10. bsft
    I am not a programmer at all and I test simtools. as long as they know it works, thats all.
    We have many beta testers with different simulator setups, and different PCs, so more saying that it works, the better.
    simtools can be installed with 2089, you can use either, They do not affect each other as long as both are not running at the same time, but obviously simtools is the new motion software to replace 2089 and other x-sim programs.
    My 85 year old mate with a wiper seat mover is a beta tester and he is no programmer. As long as it works for him, thats all.
  11. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    hi david :hi: , I get better, thanks for your explanation, but try to get into the post simtools and tells me I'm not allowed to enter :no: , so he said it's not for everyone, it is only for authorized persons, you must be one I congratulate them and, not one to ask for authorization to use :?
  12. bsft
    Send an email to Rene and yobuddy, they are busy and can direct you to the link.
  13. RaceRay
    Hamburg, Germany
    23,876Coins
    @Christianr3 i added you to the beta testing group. It´s not a magical thing to use the software so just give it a try. I send you the link via pm.
  14. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    ohh thank you! :clap: ... I will do my best to learn to use it well! ... and give my opinions on the program, several people say it is very good and easy to use, and works very well with cards jrk 12v-12, those are the ones has my simulator! :happy: ... thanks for letting me try it with me too! :yippiee:
  15. eaorobbie
    20,481Coins
    Welcome mate, fire it up any questions , happy to answer, even 1 on 1 in skype is needed, Skype address - live:netnutters. Come on and have a chat if you get any issues.
  16. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    thanks friend! I think a good idea! :D ., My skype is christianr3hotmail.com, i live in american continent ... the only problem is that they have to bear with me because I do not speak English hehehehe :uups: , I use google traductor in order to understand what they write , :hacker: but I defend well indeed thomas wrote him saying that he achieves that moves my simulator simtools, but do not understand how to configure the Valões pitch and roll :? , I'm using the version 3 that sent me rene, your using jrk? .. have a configuration that I can use? :pleasantry:
  17. value1
    15,026Coins
    I updated the Quick Installation Guide for the new beta and also added some pictures to make it easier to check and compare the settings.
    T.
  18. eaorobbie
    20,481Coins
    Im currently running Jrks withs a Seatmover in V3, I have been running Jrks since 2009 and was responsible for bring them to the site. I have built 9 different combination with the Jrks.
    Latest is a seat mover running big worm gear motors to show sim racers that for $800 dollars they too can jon in the fun and keep their beloved static sim part of their new motion sim.
  19. christianr3
    christianr3 Member
    VENEZUELA
    531Coins
    2DOF, JRK
    very technical work yours, congratulations, my engine simulator used in the front, it is important to maintain a good balance for my engines are not damaged, and consume less energy, but it's hard to get a good balance, but I'm grasping tests I will put a video of the movements of my simulator at a time to guide me if I'm on track, Greetings!
  20. hooshang
    hooshang Active Member
    275Coins
    hello Rene
    ha ha ha...so im not authorized too...:)
    looking for that "not a magical thing" ..if possible..please
    thank you & regards
    Hooshang
