questions regarding best software to use for 3DOF build
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by rt45433, Sep 18, 2013.
  1. rt45433
    rt45433 New Member
    291Coins
    Hi there,
    I am new to this site but have a few questions regarding ready made simulators you can buy online or going the DIY route.
    So I first started looking at these two simulators. They cost $22,500 and $45,000
    http://simxperience.com/en-us/products/completesimulators/stage5racingsimulator.aspx
    http://www.cxcsimulations.com/purchase/configurator/europe/2/
    I would really appreciate any thoughts form anyone who has had experience in any of these products.
    Why are these so expensive compared to a DIY option?
    Are these better than a DIY build and if so why?
    Is the software they use more realistic than x sim or sim tools?
    Basically I have a budget of about £6000 not including the triple screen setup and computer. I would like the most realistic racing sim for my money. I don't mind going down the DIY route if it will benefit me.
    I would like to use SCN6 actuators as what i have read is they offer a better feel. I would also like a rear traction loss. One of the companies above (simxperience.com) sell a starter kit which is some SCN6 actuators and their sim commander 3 software. (would this software be better than xsim or simtools?)
    Any advice or guidance would be great. i don't want to start anything until I have had some advice from a seasoned pro as leaning from others will save me an endless amount of time.
    I dont mind documenting the whole process when i get started to upload for anyone on here.
  2. eaorobbie
    20,488Coins
    Ok 3dof with a heave, ie 2DOF covering roll, pitch, sway, surge and simulating heave. Then add a third axis to capture the sway for a rear traction loss setup.
    All can be done for under $1000 dollars with card that are off the shelf , Jrk12v12 on Big Worm Gear motors.
    And can be used with our new software.
    Example of a 2Dof Seat mover built for $600 (Chair piece only) that can be adapted to any static sim, just needs a yaw table under the whole unit and you have 3dof for a fraction of the cost and its all 12v electronics, defiantly a DIY option anyone can build.
    P.s this could be done for scn5 too, but triple the price.
  3. rt45433
    rt45433 New Member
    291Coins
    Thanks for the reply eaorobbie.
    Thats the setup I think that would work best. Start with a 2DOF seat frame setup then add the traction loss by using a yaw table underneath.
    If there any difference from using scn5's to scn6's?
    Also is there any disadvantages of using your software instead of the software from say simxperience? (I would like a very realistic driving sim if possible)
    When you say using your new software, Where would i get this software from and whats it called?
    Thanks for the help so far.
  4. eaorobbie
    20,488Coins
    Ok Simxperience is a very good system, and is commercial, software here has been developed to be used by use DIY guys, a replacement for the aging software we use from another site. There is a post where you can ask to be included in the beta test, but by the time your ready hopefully we would have released this to the public.
    Ok scn6 can handle a greater load and are a little slower, they push the 200mm/s mark when loaded on a sim, my dc motors are pushing way past that speed.
  5. RacingMat
    21,060Coins
    It's called Simtools !
    You may send a PM to Raceray to apply to beta testing
  6. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    I am starting my build, AC Platform....already had the "other software" - but reading and pm's with yobuddy, I've scrapped that direction -
    SimTools is now my direction.
  7. Historiker
    9,208Coins
    I thought that Simxperience was proprietary in that it only worked with the controller sold by that company? I might be wrong though. I did not think you could do DIY with their motion software.
    I did buy SimVibe from them for adding vibration feedback into your sim and although it is a nice program there are too few games supported and almost none are flight sims :(
    But I admit, if the wife would like me mortgage the farm I might buy a complete system ;)
  8. bsft
    welcome rt45433
  9. RaceRay
    Hamburg, Germany
    23,877Coins
    @rt45433 hope you will never forget your username lol
    Nevertheless, Welcome at xsimulator:)
