display for custom pedals
Discussion in 'DIY peripherals' started by mario73, Sep 28, 2013.
  1. mario73
    mario73 New Member
    Mecchanik
    Monza
    382Coins
    DC motor
    Hi guys i use a type s load cell and it work for 0 to 100kg ,my brake pedal is equipped with adjusting screw to adjust the hardness, but I can not determine exactly how many kg. for this I thought to display them on a display.
    now to run my pedals use the buo836lc, it would be possible to use arduino (or other card that gives me the ability to view kg or on a display or directly in the settings-gaming of windows) to interface my pedal board to the PC? in order to be seen by rfactor thganks for the help
  2. RacingMat
    21,088Coins
    Hi Mario !
    The load cell spec should give you the conversion between Volt and Kg
    If not, you can say that 100kg max would be 5V and apply a proportional rule.
    Simply use DxTweak to see the result in live when you will press the pedal.
    http://www.wingmanteam.com/latest_software/gadgets.htm#DX Tweak 2
    You can have a look on what I did here
    from this french post google translated http://translate.google.fr/translate?sl=fr&tl=en&js=n&prev=_t&hl=fr&ie=UTF-8&u=http://www.gamoover.net/Forums/index.php?topic=28158.0&act=url
  3. ferslash
    ferslash Active Member
    4,798Coins
    how are you planning to interface the cell with the usb port - joystick side?
    best regards
    fer
  4. RacingMat
    21,088Coins
    @mario73: did you manage to calibrate your load cell?
    @ferslash: there are several ways: leobodnar board, dismantled USB joystick... let's wait and see what Mario has chosen
  5. mario73
    mario73 New Member
    Mecchanik
    Monza
    382Coins
    DC motor
    in this moment i use a buo836lc but my idea is:display reading kg in the configuration screen gaming of windows( see the photo for one example) this is a optimal work for an calibration of the brake pedals ,but I do not know what it takes to make this work thanks
  6. bsft
    thats a lota buttons!
  7. eaorobbie
    20,506Coins
    A custom app could be written in Visual Basic, not sure if a base code is available. Need to Google that one.
