prilad
IL-2 Sturmovik: Cliffs of Dover Plugin 2.0.0.1
SimTools game plugin for IL -2 Shturmovik "Cliffs of Dover"
  1. prilad
    Dubna, Russia
    9,648Coins
    3DOF, DC motor, Arduino, 4DOF
    prilad submitted a new resource:
    IL-2 Sturmovik: Cliffs of Dover Plugin - SimTools game plugin for IL -2 Shturmovik "Cliffs of Dover"
  2. prilad
    Dubna, Russia
    9,648Coins
  3. Historiker
    9,207Coins
    Everything works good with the exception of surge, which is very weak and seems to "jitter" back and forth. The values coming out of Simtools is too low to adjust; -1.2/1.2 or so. I turn Yaw up and Sway down as they seem to be mixed. With Sway all the way up it takes over completely. I think it gives a realistic sense of movement though.
    Extra 1 is the same as Yaw, no difference seen there.
    Well done! And thank you!
  4. prilad
    Dubna, Russia
    9,648Coins
  5. prilad
    Dubna, Russia
    9,648Coins
    Sorry, I forgot to mention that now necessary to specify the installation directory of the game when you patch it.
  6. eaorobbie
    20,452Coins
    As special request for Hugso , could we may be put in Air Speed to the Exra1 DOF so he may uses this for his Sim, I know its not a force but he uses this too affect the motion of his rig.
    Thanks on his behalf
  7. prilad
    Dubna, Russia
    9,648Coins
    Hi, Robbie. This plugin provides pitch, roll, heave, yaw, sway and surge acceleration.
    Added an parameter slip (as Extra1)
    As I know Hugso has success with CloD plugin... Not? What do you mean as "Air Speed"?
  8. eaorobbie
    20,452Coins
    Ok been fiddling with the DCS plugin, must get back to it soon, to add the indicated air speed into the one of the extra forces, he uses this to control a dampener effect on his flight sim.
  9. prilad
    Dubna, Russia
    9,648Coins
  10. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    Sorry to appear an idiot, but I am not clear where the Installation Directory for CloD is. Is it via Documents/1C Softclub/CloD/Missions?
  11. Historiker
    9,207Coins
    I assume that you have a Steam installation? It should be under steam/steamapps/common/il-2 sturmovik cliffs of dover/missions/single/
  12. prilad
    Dubna, Russia
    9,648Coins
    No... For last (3.0.0.8) plugin version you should to pick Installation Directory ,instead for previous version... If you install CloD to default directory it may be like this path
    "C:\Program Files (x86)\IL-2 Sturmovik.Cliffs Of Dover.v 1.02.14821"
  13. hugso
    hugso Active Member
    Glos UK
    611Coins
    I don't have IL-2 Cliffs of Dover in my Program Files. It is partly in My Documents and 1C Softclub etc and the other part is in Steam\SteamApps\common\il-2 cliffs of dover. I tried patching into the StemApps\common\il-2 and the patch seemed to go in, but I could not get any data out in flight.
  14. prilad
    Dubna, Russia
    9,648Coins
    :think
    Can you write FULL path to next folders -
    "...\parts\bob\mission\Quick\" (it should be in instalation folder)
    and
    "...\missions\Single\" (it should be in Docoments folder)
  15. hugso
    hugso Active Member
    Glos UK
    611Coins
    Local Disk(D)\Steam\SteamApps\common\il-2 sturmovic cliffs of dover\parts\bob\mission\Quick\
    Documents\1C SoftClub\il-2 sturmovic cliffs of dover - MOD\missions\Single\
    These are the full paths on my machine. CloD first plugin worked fine.
  16. prilad
    Dubna, Russia
    9,648Coins
    Ok. I understand the problem... I hope I can solve it.
  17. hugso
    hugso Active Member
    Glos UK
    611Coins
    I feel I am giving you grief. All I do is find problems. I hope their is some way I can repay you for your fantastic work.
  18. prilad
    Dubna, Russia
    9,648Coins
  19. hugso
    hugso Active Member
    Glos UK
    611Coins
    Hi prilad, that is brilliant! Thanks a million. I will have a go with it later. I have had a think about the Airspeed movement and I now realise I can easily adjust my set-up to use 90 degrees of movement instead of 180 degrees. In fact in some ways 90 degrees is better. I wish there was some way I could buy you a beer or three for this. I will post a video of me flying around later next week. I hope...
  20. hugso
    hugso Active Member
    Glos UK
    611Coins
    Finally have had some time to have a good fly around in Team Fusion MOD Cliffs of Dover. Loving it, such glorious scenery and graphics, and my 4 dof motion platform cockpit feels great. Everything tipping and bumping as it should. Highly delighted. Is there any possibility of having SimTools active in Full Mission Builder as well as Single Missions? It would be great to be able to choose which airfield I can start from and what I am going up against.
