Arduino uno wiring diagram
Discussion in 'SimTools compatible interfaces' started by hooshang, Nov 9, 2013.
  1. hooshang
    hooshang Active Member
    275Coins
    :thumbs@eaorobbie
    nicely done
    but let me ask you that have you ever tested this cofiguration before?
    and let say i tested this today and may somthing goes wrong
    with it!?although you did this diagram based on Arduino code: 2DOF and 2 pins direction Hbridge, but it didnt work properly and then when i
    changed no:4 pin with no:7 ,it just seems get allright!
    thank you
    Hooshang
  2. eaorobbie
    20,481Coins
    No I havent tried this code because I use jrks, dont want to step backwards.
    But if this is true then the pin out @RacingMat has posted is in correct, thinking back when I was using the Monster Moto Driver from Sparkfun there was a error in the silkscreen, I had to change the pins from memory to get it to actually work with the K8055 but dont remember what I did - 2 years ago.
    @RacingMat can you confirm the pin out is correct, verified and works.
    Either that or there is a error in the actual code. Not sure.
    Again I only created the diagram from @RacingMat text. Sorry if this is confirmed to be right Im happy to change the diagram for you guys. Only posted to help people like yourself understand where to pin everything in. Thanks for finding the error.
  3. hooshang
    275Coins
    cause we can see the name Arduino all over the community ,its not bad
    to have confirmed code and diagram or any alternative code and diag.
    all together here...for this board
    regards
    Hooshang
  4. prilad
    Dubna, Russia
    9,658Coins
    3DOF, DC motor, Arduino, 4DOF
    You can find my Ard firmware AND wiring diagram here:
    http://www.xsimulator.net/community/threads/arduino-uno-duemilanove-2dof-firmware.4564/
    And other firmware authors, as I know, posts wiring diagrams. Where do you see the problem?
  5. eaorobbie
    20,481Coins
    I would recommend using @prilad code as I have actually tested this with both the Monster Moto and Pololu driver and was surprisingly impressed with it , plus his little app makes it so much nicer for the end user to setup, bonus thanks @prilad.
    They might post wiring diagrams but from @hooshang test they seem to be incorrect for the driver stated , just would be nice that the correct information is posted, we are only human mistakes do happen. Thanks @RacingMat for fixing it , by the way I had an issue trying to load the code from the download too, had to copy & paste from notebook to Ard IDE in order to compile it, as it would not load from you downloadable file. Anyone else had this issue ? or just me, mmm.
  6. yobuddy
    51,005Coins
    If your going to use the Ard, I would also recommend using @prilad code!
    I have noting but good feedback from it's users.
  7. hooshang
    275Coins
    hi freinds
    i use Prilad code and the initial tests with pot was great and smooth
    but i have problem with transfering data to Arduino ,iam using
    interface presetting of Racingmat for Arduino,i dont know if this is the point
    or i have another problem...???o_O
    thank you
    Hooshang
  8. prilad
    Dubna, Russia
    9,658Coins
    data string:
    AB<255><Axis1><Axis2>
  9. hooshang
    275Coins
    @prilad
    thank you friend for the great code
    and how about start up and shutdown output?
    regards
    Hooshang
  10. prilad
    Dubna, Russia
    9,658Coins
    Hi, Hooshang. You do not need to use startup and shutdown data
    Only set correct Baud for used firmware.
  11. hooshang
    275Coins
    @prilad
    thank you
    your zipped file contain 5 differnet code, how should
    choose one?!and why?
    regards
    Hooshang
  12. prilad
    Dubna, Russia
    9,658Coins
    All files has the same functionality and has only different Baud Rates. You can try any. If you obtain some troubles with communication - try another...
  13. hooshang
    275Coins
    i have still communication problem
    let say i have 2 Arduino uno board,
    i programmed the first one with Racingmat code and
    no actualy problem with commuinication,using Racingmat
    code and interface preset...then i used Prilad code (19200 and 28800)for second one and preset as he said (AB<255><Axis1><Axis2>)...
    boards led is on,in output testing when i click turn on botton
    Arduino RX led also gets on but...
    still no data:( comming to the driver:sos
    thank you
    Hooshang
  14. eaorobbie
    20,481Coins
    Have you been able to use it in his app that goes with it, recommend setting it up first before Simtools the above settings should work. Check the interface settings are correct for the code you are running.
  15. hooshang
    275Coins
    @eaorobbie
    hi freind
    app? if you mean Xloader,yes i programmed my Arduino(Prilad code) with it.
    if somthing eles,i donno
    and here is my interface settingas Prilad said:
    thank you
    Hooshang
  16. prilad
    Dubna, Russia
    9,658Coins
    Why you set 115200 baud rate? You should set Yours Firmware Baud Rate (28800 or 19200)
    Check it please. Yes, I posted this picture, but I wrote
  17. hooshang
    275Coins
    @prilad
    first,thank you
    then i loaded code 19200 and new interface output setting
    but still no data come to the board :mad:
    pololu drive and wiring nicely work
    cause the motors respond very well to the pots positions
    but they are still waiting for data to act :roll
    thank you
    Hooshang
  18. prilad
    Dubna, Russia
    9,658Coins
    I'm not sure, but may be it can be important to write <Axis1> (with a capital letter) instead of the <axis1>.
    Xloader
    have upload firmware with BoudRate 115200 - for UNO its wright. But SimTools should be configured with BaudRate which used in Firmware.
  19. hooshang
    275Coins
    @prilad
    Thank you for quick reply
    Eaorobbie said about the presetting with an app ?!
    Could you please tell What is he talkin about?
    Thank you
    hooshang
  20. eaorobbie
    20,481Coins
    Extracted from @prilad post on the firmware, not sure where the download is for it anymore.
