can build 6DOF by using 3 Arduino bord?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by aboodix5, Dec 1, 2013.
  1. aboodix5
    aboodix5 New Member
    Baghdad-Iraq
    328Coins
    hi every body
    i thinking to do the idea. using 3 arduino board so that take me 6 axis.
    and the simtools support more than one interface .
    That possibly or not?
  2. value1
    15,032Coins
    Welcome aboodix5!
    SimTools supports up to 6 individual interfaces. This will not be the limitation.
    Have fun here!
  3. aboodix5
    aboodix5 New Member
    Baghdad-Iraq
    328Coins
    thanks value 1
    this simple diagram to my idea
  4. eaorobbie
    20,481Coins
    @aboodix5 Yes this is correct. You can have one Ard per Interface Tab in the Game Engine.
  5. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
  6. vell001
    vell001 New Member
    559Coins
  7. kermit76
    kermit76 New Member
    The Netherlands (Zwolle)
    357Coins
    That's a good idea!
    I'm hope to follow your preformens
  8. berty
    berty Member
    164Coins
    Also concerned about the tie, it uses 3 arduino uno board, but you can use one Arduino Mega board however I do not know how to load firmware into it. But thanks for the reply, that even when using only three Arduino Uno its possible.​
  9. RacingMat
    21,050Coins
    One Motomonster can drive 2 motomonster for example: hence 4 DOF
    yours
    Mat
  10. aerofotocol
    aerofotocol Race Fast, Flight Low!
    Mechanical Engineer
    Miami, Florida
    308Coins
    You can use Thanos board :)
  11. berty
    berty Member
    164Coins
    You are using thanos board?
  12. eaorobbie
    20,481Coins
    Which board his new one or old one ?
    Ard still cheaper and easier.
  13. berty
    berty Member
    164Coins
    I have Thanos AMC 1280 USB
  14. eaorobbie
    20,481Coins
    Good luck , only one person can help you there we don't internally support his cards.
    Arduino is way less cost and will produce about the same results.
  15. berty
    berty Member
    164Coins
    Thanks!
    And who would help me to know? Probably only motherboard manufacturer. Am I right?
  16. bsft
    we only use ards here these days. Stick with them.
    Thanos makes his own boards and he is the only support for them, so dont expect it to be cheap.
    simtools and x-sim neither support thanos boards. If you choose to use them, you do at your own risk.
    Theres no motion software for thanos stuff that works, and his code is not quite right and costs a heap to get right, etc , etc.
  17. berty
    berty Member
    164Coins
    Thanks!
    It's not good news for me, but a mind. So get to work with Arduino boards. Thanos board leave on the shelf. :) :)
  18. eaorobbie
    20,481Coins
    Ah no you can use his board without issues.
    If you can inform us the commands it needs to operate, ie the interface settings (old software made up name USO settings) we sure can advise on how to setup simtools.
    No issues in using his cards if you already have it.
    Sorry did not mean to discourage the use of them.
    I just feel they are quiet expensive for what they can do.
  19. berty
    berty Member
    164Coins
    No, you did not deter me, but first I should try it with Arduino, which are easier to set and then moving on to Thanos board. The setting certainly I need help with simtools because I still did not work. Only in the x-sim.
    So far thank you! :)
  20. eaorobbie
    20,481Coins
    Please provide the setting you used in XSim and I can happy advise on how to setup SimTools and take you through the basic setup sequence to get it moving. No worries.
    • Friendly Friendly x 2
