Rfactor plugin problem
Discussion in 'SimTools Plugins' started by bartez81, Dec 2, 2013.
  1. bartez81
    bartez81 i like amps Gold Contributor
    Kraków
    - 22Coins
    2DOF, 3DOF, DC motor, AC motor, SCN6, Arduino, JRK, Motion platform
    Hello simmers.
    I had some problem with rfactor plugin. I just intsall it by Pluginupdate (succeesfull) but when i try start game sim does not move. I have information game running but nothing more. i Try DOF move and works ok. Please help me...
    On xsim works like race-deamon.
  2. value1
    14,175Coins
    Right-click on the GameEngine Tray Icon GameEnginTrayIcon.jpg and select Tuning Centre Open TuningCentre.jpg
    A window opens with lots of data:
    Click on Capture Max Min and then on Reset
    Run your game and drive an average round without crashing.
    Save New Settings and Stop Capture
    Now you should have greater movements of your sim.
    NB: The lower the MaxMin values in Tuning Centre Game Limits, the stronger the movements.
    Have a try.
    Thomas
  3. eaorobbie
    20,491Coins
    Or please read the manual, need to patch the game in the Game Manager.
  4. bartez81
    Kraków
    - 22Coins
    Game
    game patched when i start game i see game running in game manager but there is no motion.
  5. value1
    14,175Coins
    Hi @bartez81
    Have a try with the Tuning Centre approach.
    If you see changing numbers in the "Game Data - Input" fields, you're on good track. Most probably you will only have to adjust the Max/Min values to get proper motion.
    If you see no flickering data in these fields, please let us know.
    We will nail it down together :)
  6. eaorobbie
    20,491Coins
    Ok another to check if no data or motion is available ,is the Game Engine - Axis Assignments - Rfactor and make sure you have axis data set for the game.
    You may have already set your default axis and when you installed the game plugin it copies the default axis to the Rfactor Axis Assignments. Might be part of the issue, might not.Sorry am trying to help, please excuse my bluntness.
  7. bartez81
    Kraków
    - 22Coins
    Dont apologise im very glad for your help. I will check it today. Regards
  8. bartez81
    Kraków
    - 22Coins
    Ok a have no data in Tuning center.
  9. bartez81
    Kraków
    - 22Coins
    I have to make some big mistake. I do not work for me any game. Only Grid...
  10. bartez81
    Kraków
    - 22Coins
    ok i fund problem. I had to reinstall simtools. I see wthis works not only with windows :)
    Thank you eaorobbie for help.
  11. eaorobbie
    20,491Coins
    Yes mate, written for windows only, has been tested in xp , 7 and 8, vista = no.
    Glad to here your up and running, please take the time to enjoy.
