Static sled to 2 DOF sim.
Discussion in 'DIY Motion Simulator Projects' started by davepeebs, Dec 9, 2013.
  1. davepeebs
    davepeebs New Member
    G.M
    Sydney Australia
    619Coins
    Greetings all,
    I built myself a sled style sim a while ago and was very happy with it until I stumbled across this web site.
    Thanks to the generous sharing of knowledge by the members here I am on my way to converting it to a 2 DOF sim.
    My plan is to have the seat, pedals and wheel move but keep the screen static.
    Here is what I started with.
    After reading through many posts by you guys, this is how it is shaping up.
    Please disregard the blocks of wood holding it level at the moment, this is so I can still use it while the build progresses. GT6 came out last Friday and I was keen to give Bathurst a go.
    The tricky part with my build is that I want to keep as much as possible adjustable. I have 2 young boys 5 and 7 and I want them to be comfortable playing it as well.
    I have the pedals sorted, but the steering length or closeness to the seat will be tricky. With the sled style I could move the seat forward and adjust the steering up or down, anyway I will nut that one out soon.
    I will be running Arduino R3 with Monster Moto board (probably) as I have these already.
    I look forward to loading up your software and trying to figure it all out.
    Does anyone have a wiring diagram or schematic on how to connect the Ard to the Moto? I know they can stack, but do I need to use all of the pins?
    Thanks again guys, you are an inspiration.
    Dave.
  2. bsft
    Hello Dave, nice setup. The motor placement is ok, as long as you are not too heavy a chap, like over 110kg. I have tested my big motors on about 6 different designs for best placement in regards to compactness. If it struggles, you may need to space motors out a bit, but give it a whirl first.
    As for main adjustable for younger kids, been there , done that. My older boy is now 10 but has been my test pilot on all my builds since he was 7. So adjustabilty was the key . Pedal placement was easy and when he was younger I would put the booster seat in, move pedals towards him, no probs.
    I have a mate whom has mounted his seat mover setup on seat rails to make it easy for him to get in and out. So motors, and control boards all in one on rails.
    As for steering adjustable, I made a slider setup on one sim, where as I cut out slider holes in base of steering mount, then made a plate with nuts on it for wingbolts to tighten against. So I can slide it back and forth and tighten to hold into place. So it moves back about 90mm towards the younger driver.
    You can get the Mount Panorama track on GRID2 as DLC. Its awesome.
    Or you can get rfactor and download Bathurst track for free.
    Simtools only runs PC games, so no motion from consoles.
    Go Hard.
  3. davepeebs
    G.M
    Sydney Australia
    619Coins
    Hi Dave,
    I just built up a pc for Simtools and the sim and got Grid2, Dirt3 and F1 13 for pc to start with.
    Awesome to know I can get Bathurst for Grid2!
    I will have to get RFactor as well, a mate of mine races every Mon night on there.
    I would have placed the motors a bit further apart but I was lazy and just used a section of the donor golf buggies frame, pretty solid but too close together.
    As you said I will try it out first and change it if it needs it. As i am just over 100kg it may be a problem.
    Dave.
  4. bsft
    Give it a run first , It may just do fine. If it works, leave it.
    Bathurst for GRID2 is apparently the same as Forza 5 Track. I heard codemasters worked with the forza team. Motion is good out of GRID2, not the best minor vibration from bumps, say like Race07 , but a great drive. Rest of motion is good.
    As you have Dirt3 and GRID2, Rob and I plus a few others race GRID2 on fridays and saturdays moslty after 10:30pm EST. We also play RACE07 and DIRT3. We use our own paid mumble server.
  5. eaorobbie
    20,506Coins
    Ok wiring diagram that all depends on whos code you will use.
    Most of the codes show the pin out but few have pretty pictures.
    I recently complete one for RufusDufus code but using a different driver than the moto.
    Select a code to use, and we can discuss the wire up mate.
    And yes welcome to come race, Friday and Saturday nights.
  6. davepeebs
    G.M
    Sydney Australia
    619Coins
    Thanks guys, you are both very helpful.
    I didn't realise it depended on which code you use.
    I have down loaded a couple, which would you suggest?
    Stable and user frindly are ideal I guess.
    I read somewhere on here that racingmat's code was good.
    I am open to suggestions.
    Cheers.
  7. eaorobbie
    20,506Coins
    Well most of the arduino code is not really newbie friendly, or that easy to use, Jrks are much easier, but if you already have it then work from there.
    I would trial @RufusDufus new code, comes with a application for setting the Ard up. He provides all wiring details, no picture thou.
    One that has proven to be usable is @prilad 2dof code but restricted to 2 dof but comes with its own utility.
    Lastly racingmats doesnt use pid control at all its a dynamic speed code. I wouldnt use his until it is changed and doesnt come with its own app.
    Hope that makes the choice easier.
  8. davepeebs
    G.M
    Sydney Australia
    619Coins
    I think I will go with Rufusdufus' code to get going, need to work out wiring first.
    Thanks for the suggestions. I have both boards mounted in a pc power supply case with heat sink for the monster moto and a fan on the case. Should keep it cool enough.
  9. eaorobbie
    20,506Coins
    I can post a pic of wiring tonight if you so require.
  10. RacingMat
    21,088Coins
    Hello Davepeebs!
    The Arduino code I published, is simple as possible : it's a good way to introduce yourself to arduino and sim motion.
    The code is a PID but only with the Proportionnal term ;-)
    Proportionnal term is based on difference between (actual position - aimed position).
    And speed is adjusted along the proportionnal error.
    Prilad and Rufusdufus have published more beautiful and complex codes!
  11. eaorobbie
    20,506Coins
    Ah sorry if its only using P you cant call it a PID Controller its still a Dynamic Speed controller. Its why the K8055 has such slow and laggy movements compared to a true PID controller like the JRK. With Dynamic Speed you miss all the small very quick vibration movements, because you are close to the target, motor speed will be very minimal(slow). The D option increase this dramatically.
    Take a trip to @bsft and have a run on a Jrk machine, will blow ya mind for sure.
  12. bsft
    Granted I have not tried the code as I am code hopeless, but having D of the PID right makes a HUGE difference, even if it is a bit more complicated.
    And yes its a JRK example, but in the beginning, I had issues getting motor settings right with P, until Rob said "did you adjust D?" , Duh.....
    Ive seen people toss out arduinos, JRKS, and even tronics board because they couldnt get PID right. So doesnt matter which board, Getting PID right is important, so having P and D is important.
  13. davepeebs
    G.M
    Sydney Australia
    619Coins
    Hi guys, a drawing of the wiring would be great thanks Rob.
  14. eaorobbie
    20,506Coins
    Its coming mate, I got stuck last night playing Grid2 on me sim, so addictive once you have motion.
  15. davepeebs
    G.M
    Sydney Australia
    619Coins
    If I stack the moto on top of the uno with pins do I need only to connect the motors,power supply and pots?
  16. davepeebs
    G.M
    Sydney Australia
    619Coins
    I am hanging to play grid2 after bsft told me about Bathurst dlc.
  17. eaorobbie
    20,506Coins
    Do not stack it will not work, I will and promise to post a wiring drawing for you.
  18. eaorobbie
    20,506Coins
    As promised, we need @RufusDufus to confirm that I got it right, best for two to check.
    Ok picture changed 12/12 Vcc corrected to 5V.
  19. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,497Coins
    @davepeebs or @eaorobbie. Do you have a link that has the Moto Monster board pinouts? The sites I have found don't seem to provide that info.
  20. RufusDufus
    Adelaide Australia
    16,497Coins
    Ahh just found the details in the schematic.
    The only point I think might need to change is the +5V from the Arduino looks like it should go to the +5V pin on the Monster Moto (not the Vin). From the schematic it appears as though the Vin pin is not connected)
    You would setup the SMC3 to MODE1
