value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. value1
    15,032Coins
    • Like Like x 5
  2. value1
    15,032Coins
  3. McCorwin
    McCorwin Member Gold Contributor
    - 90Coins
    Sorry but I don't understand few things....
    In the cfg file all sway surge have 0 min/max but roll and pitch have values .... an error ???
    And When I test it all is ok for surge and heave but for sway, the value at the beginning of the track is -8.
    And when I keep only sway the simulator doesn't move much (or not move)
  4. eaorobbie
    20,481Coins
    ? not sure what you are doing there is no need to edit any cfg files. Or do you mean Tuning centre.
    No Limits only supports Heave,Surge and Sway, no Roll or Pitch or Yaw.
  5. BlazinH
    16,665Coins
    Hi @value1 and/or @eaorobbie . I would like to know if it would be possible for you guys to add speed to this plugin if you knew the memory location where the variable is located? As I stated in previous posts, I use a fan to emulate wind. And there is not better candidate for this than on a roller coaster simulator. I know this because I implement it already using the old software that was here previously. So I already know its location. On a force dynamics type simulator with the addition of a dual cage blower in your face, it is the most fun you can have just sitting only! I'm sure that other members that implement a "wind system" would love it too!
  6. value1
    15,032Coins
    In this case the guru is actually @yobuddy.
    Your information will help to include speed into the plugin for sure.
    Can you check with each other directly?
    T.
  7. McCorwin
    - 90Coins
    in cfg file :
    <?xml version="1.0" encoding="utf-16"?>
    <GameMaxMin xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
    <_GameName>No Limits Simulator</_GameName>
    <_RollMax>1.83970201015472</_RollMax>
    <_RollMin>-1.83970201015472</_RollMin>
    <_PitchMax>2.02621507644653</_PitchMax>
    <_PitchMin>-1.18850803375244</_PitchMin>
    <_HeaveMax>3.66627836227416</_HeaveMax>
    <_HeaveMin>-8.09702777862548</_HeaveMin>
    <_YawMax>0</_YawMax>
    <_YawMin>0</_YawMin>
    <_SwayMax>0</_SwayMax>
    <_SwayMin>0</_SwayMin>
    <_SurgeMax>0</_SurgeMax>
    <_SurgeMin>0</_SurgeMin>
    <_Extra1Max>0</_Extra1Max>
    <_Extra1Min>0</_Extra1Min>
    <_Extra2Max>0</_Extra2Max>
    <_Extra2Min>0</_Extra2Min>
    <_Extra3Max>0</_Extra3Max>
    <_Extra3Min>0</_Extra3Min>
    </GameMaxMin>
    but the only thing to do is to change like this (or to learn new limits) :
    <_RollMax>0</_RollMax>
    <_RollMin>0</_RollMin>
    <_PitchMax>0</_PitchMax>
    <_PitchMin>0</_PitchMin>
    <_SwayMax>1.83970201015472</_SwayMax>
    <_SwayMin>-1.83970201015472</_SwayMin>
    <_SurgeMax>2.02621507644653</_SurgeMax>
    <_SurgeMin>-1.18850803375244</_SurgeMin>
    </GameMaxMin>
  8. value1
    15,032Coins
    You're very creative – but you don't have to mess with cfg files.
    That's why we all love SimTools: Because of it's simplicity (once you've read the manual maybe :p )
    Right-click on the GameEngine Tray Icon GameEnginTrayIcon.jpg and select Tuning Centre Open TuningCentre.jpg
    A window opens with lots of data:
    Click on Capture Max Min and then on Reset
    Run your game and drive an average round without crashing.
    Save New Settings and Stop Capture
    Now you should have greater movements of your sim.
    NB: The lower the MaxMin values in Tuning Centre Game Limits, the stronger the movements.
    Have a try.
    Thomas
  9. eaorobbie
    20,481Coins
    If we can add speed to the dashout part of the plugin as its not really a force, and then you could have a look at the wind generator I have moved along for @Ministrinity and proberly create something of your own, or in turn your welcome to take what I have do and turn it into something better.
    @BlazinH you should have access to this link - http://www.xsimulator.net/community/threads/dash-app-and-wind-simulation-help.4962/page-2#post-48552
  10. BlazinH
    16,665Coins
    The old method used memory hooks so all I have is the speeds location. Do you implement it this way in SimTools @yobuddy @eaorobbie ? If you do let me know and I'll go look up what it's location is.
  11. eaorobbie
    20,481Coins
    Yes it does. If you can find it I can implement it.
  12. BlazinH
    16,665Coins
    All I need to do is fire up my gaming computer and see what it is. I don't have any time atm but I'll do it later today @eaorobbie .
  13. BlazinH
    16,665Coins
    I sent the information you should require for the speed value in a pm @eaorobbie . I hope you and yobuddy can get it working for other members here. If anybody wishes to search for values in a game I suggest you try the program ArtMoney. It is free at the link provided below.
    http://www.artmoney.ru/
  14. eaorobbie
    20,481Coins
    Will test over the weekend. Thanks @yobuddy.
  15. McCorwin
    - 90Coins
  16. value1
    15,032Coins
  17. value1
    15,032Coins
    @McCorwin Thanks for pointing out!
    I have adjusted the plugin for NoLimits Rollercoaster Simulator V2 Demo x64. No idea if it also works with other versions… If you own another version, please let us know.
  18. McCorwin
    - 90Coins
    Hi ;-),
    I have the 32bit version.... and it don't work... I create a "64bit" folder and copy all files of "32bit" folder to "64bit" folder , the patch done but in game all values are 0 .....
    Can you help me
  19. value1
    15,032Coins
    NoLimits Rollercoaster Simulator V2 Demo x64 plugin works with NoLimits Rollercoaster Simulator V2 Demo x64.
    Currently this is the only version I have and the plugin apparently only works for specific versions :(
  20. McCorwin
    - 90Coins
    But how can I do ??? I bought this game only for simtools and in 32 bits.....
