  1. bsft
    well...........it will be eventually for sale.......
    one sim at a time to sell. Yes I have 2.
  2. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    salve a tutti!!! Sono italiano e mi scuso per l'inglese con il traduttore automatico, ho praticamente terminato il mio sim ma ho problemi nella configurazione di x-sim, così ho provato con sim tools e mi sono imbattuto qui.
    Un saluto e la promessa che apriro una discussione con la costruzione completa anche nel vostro forum
    :cheers
    Hello everyone! I'm Italian and I apologize for the English with the automatic translator, I pretty much finished my sim but I have a problem setting up x-sim, so I tried with sim tools and came across qui.Un greeting and a promise that I will open a discussion with the complete construction even in your forum :cheers
  3. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    Webmaster allowed me to join to this community !
    Thank you René.
    We are selling SCN5, SCN6 and other component for motion simulator at affordable prices.
    We are Dyadic direct reseller and ship to all over the world!
    Thank you to all.
    Shige Tanaka
    FREX
    www.frex.com/gp/
  4. eaorobbie
    20,503Coins
    Welcome @Shige Tanaka, place some ads in our marketplace with some good prices, Im sure a couple of people might take the offer, for sure.
  5. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    my Name is Thomas and i'm from Germany. I like building thinks by myself and got some little electric experience. I have builded my first 2dof simulator and wan't to share my knowledge with you and also interested in learning something new.
  6. RaceRay
    Hamburg, Germany
    23,884Coins
    Welcome on board Thomas:)
  7. navarrma
    navarrma Member
    Mechanical Engineering Student
    Houston, Tx
    685Coins
    Hello everyone! My name is Matt, and i'm in the US. I've never played video games but racing sims are my addiction. I want to build my first motion simulator ASAP and I have money set aside for it at the moment. Does anyone have good recommendations for parts suppliers in the states or what I should use for a 2dof build? I would like to avoid using SCN type actuators and the "wiper" designs seem to be more than adequate for a first build (though I would like to use much more robust motors). Would someone be so kind as to clue me in to the benefits and drawbacks of designs that move just the seat vs a whole cockpit? Is there a generally agreed upon path for control and power supplies if I want to have the least amount of programming work to do? I will be learning as I go so i'm trying to get the basics down on my first "simple" build and then once I have a foundation in the concepts I would like to add a yaw channel and upgrade from there. Im also 220lbs and I don't know if that will play a role in the design or motor/power criteria.
    Thanks!
  8. eaorobbie
    20,503Coins
    Welcome @navarrma , big worm gears in a seatmover would be an easy start, and if you dont want to bugger with much wiring the extra dollars the Jrks cost compared to the Ard UNO out ways the pain of getting code and wiring write.
    Here is a couple of pictures to warm you up.
    P.S What you see there minus TV and G25 cost me $860 to make.
  9. navarrma
    navarrma Member
    Houston, Tx
    685Coins
    Excellent. Where should I look for the JRKS and what specs am I looking for as far as motors go and do you know a US equivalent of the motiondynamics wormgear motors that you recommend?
  10. bsft
    ill send you a PM of comparisons of sims, as for easy to get going, use these http://www.pololu.com/catalog/product/1393 , one per motor, 14v at 30 amps all day with heatsink and cooling, no code to write, simple PID, we can advise on that, 12v 200 watt big worm gear motors http://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html gearboxes are tougher than ebay jobs. Gears on pots on back of motor shaft for feedback. Power supply can be car battery with PSU on it is good. I use that as well as 2 x 12v 40 amps power supplies. I have 2 sims. For your weight, unless you want to go boat winch motors to move a whole frame, a seat mover is a good start and doesnt need huge power to move it. so 12v 200 watt worm gears will do the job.
    Please start a new thread here http://www.xsimulator.net/community/forums/diy-motion-simulator-building-q-a-faq.31/ and that way we can advise and point you in the right direction.
    Cheers, David.
  11. bsft
    F...K that was quick Rob, there are ebay daytons which are good motors and people use them. I have heard of a few user killing the gearbox on them, but that was from a incorrect design sim and too much load on motors.
  12. navarrma
    navarrma Member
    Houston, Tx
    685Coins
  13. ericRacer
    Pilot
    Canada, Quebec
    952Coins
  14. bsft
  15. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Thanks, no problemo ! :grin
  16. hamcl
    hamcl New Member
    29Coins
    Hello Simracers :) i hope i find my favorit dash
  17. bsft
  18. K1FF
    K1FF New Member
    723Coins
    SCN5
    Hi all!! I am just new to the seen live in Tassie(Australia ) just bought my starter kit today just got to wait till it gets here but looking forward to it!!
  19. bsft
    @K1FF , what starter kit?
  20. K1FF
    K1FF New Member
    723Coins
    SCN5
    Gday bsft! sx-3000-150-3ft
